Running Warm to Hot - Page 3 - Defender Source
Old October 17th, 2012, 08:50 PM
Originally Posted by bjf View Post
Talked to shop. They claim they bled it correctly but are willing to do it again with a tool that sucks the air out. At this point I have rage. Going to drive marks 90 on same hill tomorrow to see what it does.
I'm actually quite surprised you haven't gone Michael Douglas Falling Down yet. But...I did hear you recently got the vanity plate "D-Fens" which folks think is a Land Rover reference...but...
Old October 17th, 2012, 08:53 PM
bjf's Avatar
bjf
barry f
94 ST #395
Stay on topic. There are enough horsey and Jeff's on this board already. I want this fixed.
Old October 17th, 2012, 08:55 PM
My fault...I thought that's what your MECHANIC was for.
My solution: move back east where you belong, and where we know how to fix shit! This could easily be solved with a wrenching party, but you LA guys are too concerned with when the new fall styles will arrive at Nordstroms.
Old October 17th, 2012, 09:00 PM
bjf's Avatar
bjf
barry f
94 ST #395
I will say when we had a wrenching party and did my clutch I at least knew it was done right.
Old October 17th, 2012, 09:06 PM
Coming back to topic, that's the beauty of doing it yourself...half the reason I work on my own stuff is to know it's done, and done right. Now, in some cases it may take twice (or three times) as long...or in worst case scenario you may even have to re-do the work...but it's still cheaper than any dealer, and 9 times out of 10 probably done to better spec rather than just "rushing a job out the door" as many shops do (not all shops however, there are plenty of good ones out there).
Old October 17th, 2012, 09:55 PM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
For the record, a "laser thermometer" doesn't use a laser to measure temperature. The laser is just an aiming reference. The thermometer is actually just a cheap infrared sensor.
Old October 17th, 2012, 09:57 PM
I resent that, both of you. I am NOT from El Eh!
-Jeff
I wasn't lumping you in with LA...pretty sure they don't sell half-shirts at Nordstrom.
Old October 17th, 2012, 10:05 PM
bjf's Avatar
bjf
barry f
94 ST #395
I really trust the guy with my truck. I just hate that this issue only happens now idling on one street. At least it doesn't run hot climbing or in traffic. Half the issue is solved.
Old October 17th, 2012, 10:26 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
How old is the water pump and fan?
Old October 17th, 2012, 10:39 PM
bjf's Avatar
bjf
barry f
94 ST #395
Water pump about 1.5 years old. Fan no clue but no cracks.
Old October 17th, 2012, 11:47 PM
bjf's Avatar
bjf
barry f
94 ST #395
Also to answer Ron's question
No hydrocarbons, no loss of pressure, no oil in coolant, no loss of coolant, no bubbles in coolant, and to reiterate
Rad recored 6000 miles ago - 4 core
All new hoses 6000 miles ago
Water pump - 10000 miles ago.
New t stat - now
New fan clutch - now
Old October 17th, 2012, 11:56 PM
What you need is my ECUmate or the rover gauge to measure the coolant temp sensor directly. This will tell you if it's actually heating up or it's just and electric / gauge issue
Old October 18th, 2012, 12:11 AM
bjf's Avatar
bjf
barry f
94 ST #395
Link to where to buy?
Old October 18th, 2012, 12:24 AM
chris snell
Chris Snell
87 Ex-MOD 110
Apparently not ecumate.com:
We can ship to most locations worldwide, with the exception of USA and Canada.
Old October 18th, 2012, 01:01 AM
bjf's Avatar
bjf
barry f
94 ST #395
Rover gauge?
Old October 18th, 2012, 03:26 PM
bjf's Avatar
bjf
barry f
94 ST #395
Took marks truck on the same hill. Truck runs exactly the same (below middle on gauge). At the top of the hill though when I idle it goes to middle and stops even when I let it idle for 20 minutes. Wonder if I should just replace water pump again.
Old October 18th, 2012, 03:38 PM
Replace that rear crossmember while you're at it.
Old October 18th, 2012, 03:42 PM
bjf's Avatar
bjf
barry f
94 ST #395
Thanks for adding value as always.
Old October 18th, 2012, 03:45 PM
3 pages of everyone telling you the same thing over and over...yeah that's progress...
Old October 18th, 2012, 04:02 PM
mlorman's Avatar
mlorman
Mark Lorman
95 ST #2782
Here we go
Running Hot with a/c on Campbell Defender Technical Discussions 44 September 2nd, 2011 06:22 PM
Slow driving = Hot running Burke Defender Technical Discussions 15 July 24th, 2007 09:43 AM
DS Running light? Eric Siepmann Defender Technical Discussions 1 June 27th, 2004 07:55 PM
Running Hot??? Burke Defender Technical Discussions 10 March 21st, 2004 02:33 AM
Running like Sh*t...PLEASE HELP! roverboy Defender Technical Discussions 4 December 5th, 2003 12:49 AM
