Running too cool? - Defender Source
Old October 18th, 2015, 12:05 PM
WeBeCinYa's Avatar
WeBeCinYa
WeBeCinYa
94 ST #84
I've searched, but not found clear answers. Background: Over the summer, my truck ran a little warmer than I liked. Slightly over the straight up and down line. I had a new fan clutch, 160 degree thermostat, and new cats installed along with a coolant flush and new belts. Truck ran perfectly after in 90+ degree weather. Temp gauge was nicely below the center. This weekend, the weather has been substantially cooler and my truck seems to be running on the much cooler side. See pics below. Temps in the high 40's mid morning and 60 by afternoon. I went out on a few drives and below is where my gauge sits. Is this running too cool? Should I have stayed with a 180 thermostat? Shop recommended 160, but I'm not sure if that's keeping me just right in the summer, but too cool in fall/winter. Manuel says position in the "black" is normal.
ID:	132589 Click image for larger version
1994 Defender 90
2006 LR3 SE
1996 Discovery I (sold)
1991 Range Rover Classic (sold)
1995 Range Rover Classic (sold)
2006 LR3 SE (sold)
Old October 18th, 2015, 12:12 PM
180 degrees will make your engine happier AND your heater will actually produce some heat. 160, not so much.
Old October 18th, 2015, 12:17 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
I would start with a new VDO gauge and sender with real numbers, are you using ETC4765?
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old October 18th, 2015, 12:22 PM
WeBeCinYa's Avatar
WeBeCinYa
WeBeCinYa
94 ST #84
Heat was warm, not hot, but plenty warm. Yes I do need to get a VDO gauge. Is it ok to run like this until I can get shop to switch it to 180? In other words this won't hurt engine?
1994 Defender 90
2006 LR3 SE
2006 LR3 SE (sold)
Old October 18th, 2015, 12:42 PM
roverman2010
1985 LR 90 200Tdi
Have them fit a genuine WaxStat 88 deg c. It is only a 15 min job with two bolts to undo.
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
Old October 18th, 2015, 12:50 PM
No you won't hurt your engine. Your gas milage may suffer but for the short term you are fine.
Running rich and now not running Big D Defender Technical Discussions 3 May 9th, 2007 01:58 PM
Who's too hot? AC For Sale revor For Sale - Parts 3 June 5th, 2005 12:18 PM
vent control too loose artm Defender Technical Discussions 2 April 19th, 2005 07:49 AM
ECR New SS Exhaust Kits Coming soon TDI Too TDI Guy Misc. Chit-Chat 19 October 22nd, 2004 05:16 AM
OME shocks are too long on rear axle... wicks Defender Technical Discussions 5 October 6th, 2003 02:39 PM
