Running Tdi without radiator? - Defender Source
Old October 11th, 2012, 07:47 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
I'd like to do a run test after timing belt change but without radiator, in case I have to pop open front cover again. Is this realistic? no ancillaries running, no fan, coolant pump, alternator or ps pump, just filling the block with coolant and making a loop on oil cooler hoses.
- Charles Eames
Old October 11th, 2012, 08:07 AM
That sounds like a lot of work considering the radiator doesn't take very long to install/remove. How long are you trying to run it?
Old October 11th, 2012, 08:16 AM
rovertek's Avatar
rovertek
chris
D130, 2001+99 p38
double check your timing marks ...put rad in and button it up ! yes you can run the truck with no rad only for a short time heat builds fast in a tdi by the time you fab the oil line bypass you could install the rad
No Mall crawler here
Old October 11th, 2012, 08:17 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
I wouldn't think you would get a good determination on how everything is running until the engine heats up to normal operation temp? The thermostat will be closed, no coolant to the engine, until it reaches temperature. So I guess you could block everything off and run it but I wouldn't do it too long. Are you trying to see if everything is lined up correctly?
Land Rover 110
Old October 11th, 2012, 08:26 AM
I wouldn't short cuts can prove expensive.
Old October 11th, 2012, 08:37 AM
broadstone's Avatar
broadstone
'84 CSW 90 '74 NADA III '97 CSW 110
I ran the 200tdi without the waterpump to make sure I was on with the marks and adjusted the injection pump before closing it all back up. (never took rad. out though).
Patches are for Pirates and pants, not a bulkhead and chassis!
Old October 11th, 2012, 09:06 AM
Baldewin's Avatar
Baldewin
Chris Baldewin
Bastard 90
From what it sounds like you want to fire it up to see if it sounds normal and is running smooth. For a couple of minutes this won't be a problem.
Old October 11th, 2012, 09:20 AM
the only shortcut I would take is just test filling the radiator with water instead of coolant. you can dump it and fill the mix when you are set. treat that aluminum head like it was a farm fresh egg.
Mark Kellgren
KM4BOR
Old October 11th, 2012, 09:51 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Almost good for a signature line
- Charles Eames
Old October 11th, 2012, 09:59 AM
I've run them without the rad or timing cover just to make sure the belt is tracking properly.
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old October 11th, 2012, 10:02 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Damned I miss that sound !
- Charles Eames
Old October 11th, 2012, 10:12 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
If you run it with no ancillary belt, like in this video, then there is no point in installing the radiator because your coolant pump won't be working.
- Charles Eames
Old October 11th, 2012, 07:29 PM
Guess I put the rad on anyway since it wasn't my engine. Also for the sake of the oil cooler.
Present:
1987 RRC- "Chewy 2"
Past:
radiator, tdi
radiator frame top plate -- tdi Abrooks Wanted 8 August 17th, 2012 04:36 PM
200 tdi radiator replace, reduild? jayz Defender Technical Discussions 6 August 22nd, 2011 12:23 PM
tdi radiator D90user Defender Technical Discussions 1 July 24th, 2006 02:21 PM
Tdi Radiator w/5K miles dmarchand For Sale - Parts 2 December 12th, 2005 08:58 AM
WANTED: 300 tdi radiator, new or used. In a bind! dmarchand Wanted 0 June 30th, 2005 04:35 PM
