Running speaker wires to rear - Defender Source
Old December 10th, 2004, 11:41 PM
artm
Arthur Maravelis
97 SW
Anyone know how these are routed in a 90? I need to fit a pair of speakers to the rear of the 110 and the 90's in the shop. I'll be fitting the amp under the passenger seat.
Old December 13th, 2004, 10:00 AM
You could run them with the break light wires, I know in the 90s the wires all come up behind the rear PS speaker.
Old December 13th, 2004, 10:04 AM
artm
Arthur Maravelis
97 SW
So, these run under the tub?
Old December 13th, 2004, 10:06 AM
Yep, I am pretty sure they run along the fuel line. You could also run them in the bed capping's but it is kinda a pain to fish them through.
Old December 13th, 2004, 10:53 AM
NASD90
T B
None any more
they are run under the tub, buy a pack of those plastic lock tie things and follow the brake lights back towards the center cubby. you can clip the existing ties on all those wires, add your new ones, then tie them back up again (remember to clip the extra length).
I'd definately recommend using a thick gauge of cable for the speakers, as well as everything else that needs wires exposed to the ground.
Old December 13th, 2004, 11:50 AM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Not sure itf it's different year to year, but your wiring loom enters the frame tube (inside of the frame) at the passenger side bulkhead, and exits the frame tube on the passenger side behind the rear axle. That's at least how mine is on the '97.
Old December 13th, 2004, 02:42 PM
Correct, the harness runs through the frame. I see nothing wrong with doing an above-frame run so long as you make a neat job of it.
rear stock speaker boxs aschoent For Sale - Parts 14 September 28th, 2005 10:06 AM
OEM SW Rear Speaker Cover ? mattarm Defender Technical Discussions 1 March 5th, 2005 10:26 PM
Rear Speaker Boxes mlw911 Defender Technical Discussions 3 June 17th, 2004 08:24 AM
ST rear speaker enclosures TDI Guy Wanted 4 April 16th, 2004 10:46 PM
