Running rich without throwing codes - Defender Source
Old January 19th, 2009, 08:06 AM
vesparover's Avatar
vesparover
brian bertolini
Anyone else ever had this problem? Could no cats cause it? Is there anything else that would perhaps not set off the check engine light?
thanks
Brian Bertolini
Old January 19th, 2009, 02:19 PM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
What vehicule?
MonLand
1995 D90 NAS
1996 Discovery NAS
Old January 19th, 2009, 07:15 PM
vesparover's Avatar
vesparover
brian bertolini
Sorry it's a 95 defender nas.
Old January 19th, 2009, 09:24 PM
MonLand
Loic Fabro
Yes, bad o2 sensor(s) can do that. Can't remember in what situation though, but the ECU may not detect that the sensor is dying.
Now, my '95 smells like it's running rich, but emission tests show it in the normal range....
MonLand
1995 D90 NAS
1996 Discovery NAS
Old January 19th, 2009, 10:32 PM
Slow switching O2s.
You can check them with a scope. If it is just black smoke and smells rich, it is probably your lack of cats and might not be actually running rich.
Old January 20th, 2009, 07:10 AM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
If you are not running cats the motor will run rich and to correct this you need to switch to a UK non cat tune, by using the correct tune select resistor.
I think the tune select resistor is probably not present in your rig but can be added (cant remember what ECU pins to use off the top of my head but its in the wiring diagrams as well as the tune select resistor info).
Or...do the right thing and put some HP cats in it and run right as well as legally.
Matt Browne
Old January 20th, 2009, 02:21 PM
CDeWan
Clay DeWan
5.3L beastie
I have a set of used O2 sensors that were working fine out of my 94. let me know before I chuck them if you want to try them out. I changed mine out when I got new cats and went with headers.
Old January 20th, 2009, 03:41 PM
MonLand
Loic Fabro
Don't throw them out. If no one takes them, I will (eventhough I already have a set of used sensors that I still haven't had a chance to test).
MonLand
1995 D90 NAS
1996 Discovery NAS
Old January 20th, 2009, 04:05 PM
tebby's Avatar
tebby
Justin Tebbenkamp
95 D-90 ST
Same Problem...with cats
I'm having the same problem...but still have cats. No codes..and no smoke!! I was told to check my air filter first...followed by the O2 sensors...does that sound right?
wing
Running seriously rich Hans Defender Technical Discussions 26 November 18th, 2010 11:18 AM
Am I running lean or rich? johnpiero Defender Technical Discussions 1 May 8th, 2009 10:32 PM
running rich vesparover Defender Technical Discussions 2 February 6th, 2008 10:38 PM
Running Rich Please Help bstraw Defender Technical Discussions 23 October 26th, 2007 10:44 AM
Running rich and now not running Big D Defender Technical Discussions 3 May 9th, 2007 01:58 PM
