Running Rich Please Help - Page 2 - Defender Source
Old February 21st, 2006, 07:56 PM
robisonservice
John Robison
2008 Supercharged Range Rover
Originally Posted by Doug
"And all the cool kids run NGK BPR6EY Spark plugs!"
Those are hotter plugs than stock. What about pinging? I'm caught between rich and ping. Yeouch. I went all the way up to 9s but they fouled. Backing down now and retarding timing to keep the ping down.
Doug W.
I suggest a cooler plug, like Champion RN11YC, and a bit more advance.
Exotic plugs don't provide a benefit on these vehicles. The people who tell you they got "great results" with exotic plugs in my experience turn out to have other running problems that the exotic plug helped overcome. A good LR 14CUX engine just won't show a real benefit from them.
Old February 22nd, 2006, 08:36 AM
Doug W.
Hmm I thought those were the normal temp range and not the hotter temp range plugs, hmmm my 90 is running a bit on the warm side when on the highway, no pinging but I adjusted the timming so the pinging would go away under WOT. Mine runs pretty good with those plugs, hmm going to have to check NGKs site.
Old August 30th, 2007, 11:44 AM
pcscharfe
pcdefender
D90/NAS 110
Saw this old post while trying to decide on plugs for my 97 D90. Thought I would revive it to get a final answer on the NGK Spark Plug question.
Mike, did you determine whether the NGK plugs that you're running were hotter than stock?
3 questions from an amateur:
- What are the pros and cons of using a hotter plug?
- Will the timing need to be adjsuted to run them?
- Also, are there any negatives (other than cost) to replacing the stock wires with a larger gauge plug wire (8.5) in the process?
Thanks.
Paul
Old October 26th, 2007, 10:44 AM
themaxx's Avatar
themaxx
Ade
94 ST
Thanks.
Paul
What he said...
Running seriously rich Hans Defender Technical Discussions 26 November 18th, 2010 11:18 AM
Am I running lean or rich? johnpiero Defender Technical Discussions 1 May 8th, 2009 10:32 PM
Running rich without throwing codes vesparover Defender Technical Discussions 8 January 20th, 2009 04:05 PM
running rich vesparover Defender Technical Discussions 2 February 6th, 2008 10:38 PM
Running rich and now not running Big D Defender Technical Discussions 3 May 9th, 2007 01:58 PM
