Running Rear Wiring Harness - Defender Source
Old June 8th, 2016, 09:10 PM
gwmckee
George
1994 NAS D90 #1919
Hi guys - I'm to the point of re-running wiring and would like some input. Since it seems running the rear harness on a NAS D90 "in-chassis" is a PITA, I'm wondering about the feasibility of simply running it externally and would appreciate your thoughts on the subject. Thanks in advance.
Old June 8th, 2016, 09:27 PM
Use the old wires to pull the new wires
Old June 8th, 2016, 10:46 PM
mattarm's Avatar
mattarm
Matt
1993 D110
ran/pulled my 110 chassis harness using basic wire snake tool. 2 people makes the job easier. Not tough at all, just requires a little patience.
Old June 9th, 2016, 07:33 AM
gwmckee
George
1994 NAS D90 #1919
That's two "for" and none "against". Internal it is. Bill and Matt, thanks for the input.
Old June 9th, 2016, 07:47 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
bollocks.
I gave this some thought and decided to run it outside ala Chris Snell.
Didn't want to pull a 19 year old wiring harness through the holes.
Rent my
Old June 9th, 2016, 08:28 AM
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
I did the same, but also put one of those corrugated wire covers over it to protected the it while running through the chassis.
Old June 9th, 2016, 02:40 PM
mattarm's Avatar
mattarm
Matt
1993 D110
Some additional info:
  • I had better success running wire fish from back to front. I found the opening at the front to be a bit more forgiving to see the fish as it emerged up front. The rear axel curve seemed more difficult to go front to back.
  • I then pulled a lead wire through the chassis
  • I attached the fish to the end of the lead wire and then pulled the fish back through from front to back
  • I then attached the harness to the fish and pulled it from back to front
  • I did wrap the harness in the corrugated split loom
  • Loom added a bit more girth to the harness and probably added a bit of difficulty as a result but the last thing I wanted to do was damage a wire dragging it through the chassis and have to do it over again.
On the front end of the loom I did remove all of the bullet connectors which probably made it a bit easier to pull through the chassis. I wasn't planning on using them on the truck so I sacrificed them early. My plan is to go with a weatherpack style connector(s).
Not that is matters but I did also add a few wires to the harness "just in case" for any future needs that might spring up. Figured since I was in there and pulling it through anyway that it would not hurt.
Old June 9th, 2016, 02:56 PM
gwmckee
George
1994 NAS D90 #1919
Thanks Matt. That's actually a great idea to add a few "just in case" wires to the loom. I think I'll do the same thing.
wiring
Rear 110 wiring harness lrnasd90 Wanted 7 February 24th, 2014 05:14 PM
Rear wiring harness 97sw Campbell Defender Technical Discussions 4 July 26th, 2010 07:31 PM
NAS rear door wiring harness Best4x4 For Sale - Parts 0 June 10th, 2010 04:12 PM
Rear wiring harness CDeWan Wanted 1 October 28th, 2009 06:17 AM
WANTED Rear wiring harness for early D90 rgrrvr Wanted 1 October 28th, 2007 04:30 PM
