Running into power/hesitation issues - Defender Source
Old November 24th, 2006, 09:09 PM
rvrchuck's Avatar
rvrchuck
Chuck Hester
1995 D90
Hey gang,
The last few times I've been out in the 90 cruising at highway speeds (or as fast as I can get the bread box to go down 95) for extended periods of time I have experienced substantial (but luckily brief) hesitation from the beast as if she's starved for fuel for a brief moment. This generally has only lasted a few seconds at best, but when cruising at highway speeds and having the sudden loss of power I start to worry.
I have checked the fuel filter and it does not appear to be clogged. Points checked and plug wires don't appear to be an issue. Rotor and cap seem fine. My next guess is the fuel pump...anything else I'm missing here guys/gals? Anyone else have this issue with the 3.9 liter?
Thanks!
Roverin' Chuck
'95 AA Yellow 90
Old November 24th, 2006, 09:52 PM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
I had the same problem. I replaced my plugs and plug wires and the problem went away. For good measure, run some 44K through it with your next tank of gas.
UPDATE: Oh, there was one other thing that may have been causing it. The wires going to the coil had some iffy-looking connections on it. I cleaned the contacts and re-crimped the ends with a pair of needle nose pliers. Be careful when doing this. You could get zapped. Also, the plug wire going from the distributor to the coil was especially sketchy-looking. Probably a good idea to replace that one when you do your plug wires.
1987 Ex-MOD 110 Tithonus LHD
2013 LR4
Old November 25th, 2006, 10:17 PM
Billakris's Avatar
Billakris
Kris
Alpine White 95 Soft Top
Check and clean your MAF sensor.
Kris
Old November 26th, 2006, 04:43 PM
Bozman's Avatar
Bozman
Greg
1991 200tdi D90
I had a similar problem and it turned out to be the injectors. It was more of a consistent hesitation when the engine was under power though.
Old November 26th, 2006, 07:59 PM
rvrchuck's Avatar
rvrchuck
Chuck Hester
1995 D90
Thanks, I'll give those a look...injectors last. MAF and plugs/wires are easier.
Roverin' Chuck
'95 AA Yellow 90
Old November 27th, 2006, 01:06 AM
jimngo's Avatar
jimngo
Jim Ngo
1994 D90 #80
Does your D90 have the ignition module relocation kit (STC1856) installed yet? On mine I did the following:
1. Replace fuel filter
2. Replace the main & fuel pump relays
3. Cleaned the MAF sensor and stepper motor
4. Install a Mallory distributor (in lieu of STC1856)
5. Reset base idle & timing
For me, my problem was probably either one of the relays or the ignition module.
Running Rich Please Help bstraw Defender Technical Discussions 23 October 26th, 2007 10:44 AM
Dash, Running & Head light PROBLEM ! Weldon Defender Technical Discussions 5 November 9th, 2005 02:04 PM
It's Running! Mike Hippert Misc. Chit-Chat 26 June 2nd, 2005 08:04 AM
Fuel Pump running PSI and deadhead PSI? RedRhinoProducts Defender Technical Discussions 0 February 27th, 2005 02:35 PM
DS Running light? Eric Siepmann Defender Technical Discussions 1 June 27th, 2004 07:55 PM
