Running hot--new plugs? - Defender Source
Old May 9th, 2012, 07:57 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Ok, so now that it is warm out, my previously cool running D90 is not running hot when going uphill. I have a block tester, so I did that and stayed blue :-) I adjusted my timing--no change.
I put an entire new front cover on the engine--so new water pump is the only real change. Fans didn't change because I am running a dual Flexalite electric fan. While the radiator was out, I had a leak in it fixed so it should be good (it looks good, I am going to measure the temp in/out next). I changed the plugs to Bosch Platinum +2 which I have never used before and quite frankly, only got them cause they were out of the champions.
I am going to check all the culprits, including the thermostate, radiator cap, all that shit. But these are those "no gap adjust" plugs with two electrodes on them--I am leaning toward that. Since I am not going to dick around with it tonight, I just wondered if anyone has had good/bad experiences with that plug or have any ideas on this situation.
Everything runs great---and it cools down when I am not going uphill...
hmmmmmm
Old May 9th, 2012, 08:12 PM
Make sure you have properly burped the cooling system. No better ideas than that, sorry.
Originally Posted by pendy
I'm here for the D's
Old May 9th, 2012, 08:38 PM
To start with those Bosch plugs away and get a set of Champions or NGK's. BPR5EY is the NGK part number.
Did the shop flow test the radiator before they sent it out?
Running Hot with a/c on Campbell Defender Technical Discussions 44 September 2nd, 2011 06:22 PM
Slow driving = Hot running Burke Defender Technical Discussions 15 July 24th, 2007 09:43 AM
While changing spark plugs mdmccallum Defender Technical Discussions 9 November 2nd, 2005 09:12 AM
DS Running light? Eric Siepmann Defender Technical Discussions 1 June 27th, 2004 07:55 PM
Running Hot??? Burke Defender Technical Discussions 10 March 21st, 2004 02:33 AM
