Running Hot??? - Defender Source
Old March 19th, 2004, 05:29 AM
Burke's Avatar
Burke
Burke Bell
'94 NAS D90 #158
Running Hot???
For the last couple of years I have had this on again off again issue. I will occasionally notice that the temp gage is just under the red. This happens only sometimes, and it happens on hot days and cool days. It doesn't seem to matter if I am moving at highway speeds, or sitting in traffic. When it first started happening, a local garage checked it over and found nothing. I had them replace the thermostat. It did it again the next day and I took it directly to the shop where they put some gage directly on the block to check temp, it was fine although the dash gage was showing just under the red. I have lived with it, but it makes me nervous. Any ideas? Could it just be a bad dash gage? Thanks!
"I race cars, play tennis, and fondle women, BUT! I have weekends off, and I am my own boss." - Arthur
Old March 19th, 2004, 07:57 AM
dbwitt's Avatar
dbwitt
Darrin Witt
1995 Defender 90
Aluminum engine. I would change the dash gage to be on the safe side.
Darrin Witt
95 D-90 SW
04 Disco
Old March 19th, 2004, 02:50 PM
wicks's Avatar
wicks
Wicks
97 Defender LE SW #44
There are a number of parts involved in the readout on the guage so you might want to get the new guage on loan and see if anything changes.
I'm in So. Cal., 40 to 110 degrees, and it never goes over half except when crawling up a long off-road grade or something.
Old March 19th, 2004, 03:55 PM
kellymoe's Avatar
kellymoe
kevin
defender 130
Maybe clogged radiator. Have it re-rodded. Before you do that feel the radiator and feel if there is a differance in temp between top and bottom. If the bottom is cooler than the top it could be clogged?
Old March 19th, 2004, 06:00 PM
Kevin, no one around here recommends rodding Land Rover radiators, I costs to much and they die within a year.
Burke, Get a new gauge the Land Rover ones are not very reliable.
Old March 19th, 2004, 06:42 PM
kellymoe's Avatar
kellymoe
kevin
defender 130
I had a RR that was running hot and ended up just getting a new radiator at a local radiator shop after they showed me how bad it was. It ended up setting me back $100. Not bad. My 130 is running hot on hills and I was told to get it rodded. I had never heard not to get them rodded, why is that?
Old March 20th, 2004, 09:27 PM
Well, from talking to a few different Rover shops I have been told that you run the chance that it will get clogged right away or leak within a year. They also said that it will cost near as much as a new one. $100 for a new rad is good! I have heard that rodding can cost as much as $300.
Old March 20th, 2004, 10:38 PM
artm
Arthur Maravelis
97 SW
$100 for a new radiator?! Am I missing something here? Is this a direct fit? Stock or custom job?
Old March 20th, 2004, 11:06 PM
kellymoe's Avatar
kellymoe
kevin
defender 130
Went to a local shop in Burbank California. Lots of shops in the area so I think the competion helps get the price down. It was not an original Land Rover radiator but it fit and was slightly larger. Ran the truck hard for 2 years without a problem.
Mike,
I had no idea it cost that much for rodding. I also did not realize I got such a good deal on a new radiator. Even if they lied and it was just a reconditioned one I still cant complain with the results I got.
Old March 21st, 2004, 12:31 AM
castlerock4x4
Leo Hardy
1993 D 110
Don't mean to be an alarmist, but I had the same thing on my d110 and played the temp gauge, sending unit, water pump game for a year..... take it to a shop with a CO monoxide detector for the colant system and if its positive, sell your rover quick! What you've got is a cylinder sleeve leak that is intermittant, pretty common actually, where combustion gases are intermittantly leaking around the cylinder sleeve and entering the coolant system... it'll keep running for a while like that, you'll notice intermittant steam out the exhaust and you'll be loosing coolant too!. Most non Rover mechanics will tell you its a leaking head gasket, but I personally now know better.... good luck.
Old March 21st, 2004, 02:33 AM
Burke's Avatar
Burke
Burke Bell
'94 NAS D90 #158
Well, I have been ok for 2 years now since it started, no coolant loss.... I just had a 90K service done and she got a perfect bill of health. I really think it is just a simple gage (or Lucas) problem. Performance wise, just like the day I bought her in '94...
Running Hot with a/c on Campbell Defender Technical Discussions 44 September 2nd, 2011 06:22 PM
Slow driving = Hot running Burke Defender Technical Discussions 15 July 24th, 2007 09:43 AM
It's Running! Mike Hippert Misc. Chit-Chat 26 June 2nd, 2005 08:04 AM
DS Running light? Eric Siepmann Defender Technical Discussions 1 June 27th, 2004 07:55 PM
Running like Sh*t...PLEASE HELP! roverboy Defender Technical Discussions 4 December 5th, 2003 12:49 AM
» Defender Registry
Easy Button
Greenbull
Red
KGH
Add your Defender
