Running Full SD Cage "Topless" - Defender Source
Old March 23rd, 2010, 12:11 AM
nikojo's Avatar
nikojo
D90 SW -- 2.8PS
I have a SW that I plan on fitting with a full SD cage.
I'm wondering if in the summers I can run without the top. Here's the questions:
How easy is it to disassemble the SD cage enough to then disassemble the roof??
How easy is it to disassemble the room on the SW??
How difficult would it be to get a soft top fabricated to fit the full SD cage??
Would also likely have to somehow get the shoulder belt to attach to the outer cage or just run with lap belts.
The idea is to have something to run around most of summer and then have a bit more comfortable for the winter.
Old March 23rd, 2010, 12:23 AM
bharris's Avatar
bharris
Brad Harris
1994 d90 300tdi "Nola"
So... I have a soft-top so I can't _really_ answer your question but just knowing how these things go... that'd be a pain in the butt... like seriously a pain...
just the fiberglass top that is _supposed_ to come off was a serious pain but I put up with it anyway for exactly the reason you mention... but then I put a SD cargo basket on it which had to be taken off each time I wanted to switch and it just wasn't worth it so I sold the top and have stayed with a softop since... I'd bet you'd end up making a similar decision and just stick with one or the other as giving up one of your weekends instead of wheeling or something else to do something you're going to undo in a few months is likely to be not worthwhile after a couple of seasons...
Old March 23rd, 2010, 08:40 AM
ron's Avatar
ron
Ron
1994 NAS Defender 90
How easy is it to disassemble the SD cage enough to then disassemble the roof?? easy it unbolts
How easy is it to disassemble the room on the SW?? easy it unbolts
How difficult would it be to get a soft top fabricated to fit the full SD cage?? difficult for a full soft top but a surry may work
I dont know how the belts attach . but somthing could be fabed if you went with the surrey.
So soft top summer full roof in winter?
I ended up leaving mine as a soft top year round. In the end it wasnt worth the hassle switching back and forth. took about 6 hours with 2 guys.
Those who hammer their guns into plows..........will plow for those who do not.
cage
Defender 90 full Exo Cage NashvilleRover Defender Technical Discussions 19 July 24th, 2009 04:52 PM
Safety Devices Full External Cage Install D-90 JPRO576 Defender Technical Discussions 4 December 18th, 2008 10:32 AM
defender full roll cage for sale soon. mountainviewrover For Sale - Parts 5 January 22nd, 2007 02:26 PM
Full tonneau for 94, windscreen bar for softtop, ST cage, rear seat evilfij Wanted 13 June 13th, 2005 08:50 AM
Pickup cab and custom cage dave_lucas For Sale - Parts 11 January 7th, 2004 10:12 PM
