Running a cooler thermostat on Rover V8 - Defender Source
Old September 20th, 2016, 03:48 PM
Grover's Avatar
Grover
Question Running a cooler thermostat on Rover V8
Anyone ever run a cooler thermostat (<88 deg C) on a Rover V8?
Old September 20th, 2016, 04:13 PM
If it's a 14CUX truck it's going to over fuel constantly trying to get it up to temp ...
Old September 21st, 2016, 08:08 AM
carlosz's Avatar
carlosz
Carlos
easier said than done, end results could be fouled plugs, continuous rich condition, damaged cats due to excess fueling, rough idle, continuous closed loop condition, higher fuel consumption, lack of low end power, washed piston rings, difficulty starting when hot..etc.
the truck ran like a "raped ape"
A fussy warm weather creature...
Old September 21st, 2016, 08:58 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I don't know if this is true--but I heard that the genuine part thermostat (and maybe UK thermostats) have their temperature for when they are open and parts like the Stant are when it starts to open. For instance, the 180 Stant says that it starts to open at 180 and fully open at 195F. Is that true of say the 88C (190F) "OEM" version? That it starts to open at 190 or is fully open at 190?
Old September 21st, 2016, 10:49 AM
LuisC's Avatar
LuisC
Luis Constantin
98 Disvovery 1 LE
Years ago I experimented with a thermostat buy placing it in water and heating it up to a boil. The thermostat did not open gradually but popped open. Don't know if it acts the same under pressure.
Black Rhino Lives Matter
Old September 21st, 2016, 12:06 PM
WaltNYC's Avatar
WaltNYC
Walt
1997 Discovery SE
I run a Stant 45858 180 degree and get 15MPG on an engine with 134k mi. Doesn't seem to run rich.
Not sure how much cooler you had in mind.
1997 Discovery I SE - 143k mi
Library of workshop manuals in pdf format...
Old September 21st, 2016, 02:37 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I too am running the 45858---seems fine.
Old September 21st, 2016, 02:44 PM
AFAIK, most normal thermostat simply open and close at one temperature.
Stant does make the Superstat, which is meant to control a bit better. I assume their regular thermostat just ope and close at a fixed temperature.
thermostat, v8
Pelican Elite Cooler 95qt. Trades for smaller cooler or... speedpin The Flea Market 8 June 19th, 2015 01:59 PM
200tdi oil cooler / oil cooler line thread question dave_lucas Defender Technical Discussions 7 September 26th, 2012 10:56 AM
d90 running cooler 97Ariesblu Defender Technical Discussions 17 February 2nd, 2010 08:30 AM
stock adapter between oil cooler and oil cooler lines dave_lucas Wanted 3 December 23rd, 2009 02:33 PM
Installing oil cooler thermostat Doug Defender Technical Discussions 8 February 17th, 2005 11:43 PM
