Runaway Diesel 300Tdi - Page 3 - Defender Source
Old November 11th, 2010, 08:27 AM
defeyago's Avatar
defeyago
Santiago
´96 Defender 110 VGTdi SW County
It happened to mine a couple of years ago. I remember put it in 4th, release clutch and step on the brakes. That´s how I stopped it. It was the beggining of the end though since little after that I rebuilt the engine and now runs gorgeous again. The thing is I went auto conversion now and don´t know if it will do the trick if it would happen again. Here´s a video of mine´s runaway...
SANTIAGO
´97 Defender 110 Tdi SW
´04 Freelander Td4 5 dr.
´97 Alfa Romeo 146 TD (Sold)
´95 Volvo 850 GLT Estate
´94 Discovery Tdi (Webasto equipped)
Old November 11th, 2010, 09:32 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
jugando en la pampa, eh....
- Charles Eames
Old November 11th, 2010, 10:21 AM
defeyago's Avatar
defeyago
Santiago
Si seņor!!
SANTIAGO
Old November 11th, 2010, 07:20 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Video:
Runaway starts at 2:28. If you don't mind really bad language, there is great wheeling up to that point. I don't know who loaded it but it has the end missing, I think the camera guy panicked and turned it off. It does show me trying everything I can to kill it though. Including 5th gear forword.
New engine, whoopee.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old November 11th, 2010, 09:02 PM
nikojo's Avatar
nikojo
D90 SW -- 2.8PS
Thanks for posting the video.......could not have been easy posting something that painful.
I don't think I would have had the quickness to put it in gear to try and stall it. I would have been in shock trying to figure it out a while.
Loved that scene of you sideways and then getting back up.....WTF!!!!
Old November 11th, 2010, 09:31 PM
pendy's Avatar
pendy
jim pendleton
89'd90
Might have been running on all that puffed up testosterone in the air. Not its own oil.
You can send it to me and I can try to piece it back together from left over components from other damged engines.
Sorry for you loss
legend in my own mind
Old November 11th, 2010, 09:49 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Sorry for you loss
Yeah, I warned about the language. That was a different trip. Fun though. Are you serious with the offer? I may take you up on that. Can I call you?
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old November 12th, 2010, 12:12 AM
pendy's Avatar
pendy
jim pendleton
89'd90
Yeah thats fine. Just as well to get it removed and ready to ship.
Promise to post pics of the carnage here.
More awesome, less gae
Old November 14th, 2010, 07:42 PM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
Im thinking with the clutch in and things starting to sound bad the thing to do would be pop into hi range, slam it into 4th, STAND on the brakes and dump the clutch? Bonus points if you can engage all lockers and pull the handle too.
Buck from when it started to act up how long till it went pop.
------ Follow up post added November 14th, 2010 07:50 PM ------
Originally Posted by Buckon37s View Post
Edit: It's important to note that I had this engine for 8 years. When I got it, it had 50k on it. I have raced KOH where it hit 1450 egt's. I have rolled it around 15 times. All I ever replaced was a fan belt, alternator, and oil changes. I can't really be that bummed, even though I am, since I have no money right now. But the engine is a good engine. Not perfect, but very fun.
Do (did) you let it cool off any before shutting it down?
Old November 14th, 2010, 08:06 PM
navydevildoc's Avatar
navydevildoc
Neill Thornton
Originally Posted by exmod110 View Post
Halon has not been produced in years, so unless you have a secret stash it will be near imposable to obtain.
http://www.periphman.com/fire/halon-...hers.shtml#qA1
The valve type shut off works well, I have seen it in use and is very effective! but if you want an extinguisher co2 would be available. co2 can also be used to run air tools and inflate tires too, making it even more attractive for some!!
Even though Halon 1301 hasn't been widely available, there are plenty of suitable replacements. FM-200 (heptaflouropropane), Inergen (while completely non-toxic, requires a larger cylinder than others), or like you say even CO2 would do it.
If you are truly paranoid you inject the suppression agent and then close the intake. The flood suppressant also has the benefit of also being available for engine compartment fires. Find a second hand Kidde IR-1A sensor (the same thing we use on M1A1 Tanks and inside up-armored HMMWVs) to sense the fire and you have yourself a bad ass military-like fire suppression system.
Something to add to the "if I won the lottery" list.
Old November 14th, 2010, 09:27 PM
Michael
Michael
Discovery 1998
just came in on this. i am the fellow from NY this happened to back in 2005 (wow 5 years ago!!!). sorry to hear about the runaway. i still twitch when i drive by the spot it happened. mine basically warped the cylinder head and subsequently blew the head gasket. no takers for it so i still have it in the garage - should get it back together next year (i've been busy).
Old November 14th, 2010, 11:03 PM
ajh
Andrew J. Hutton
1993 Defender 110 200TDI
Why not fit an inversion switch that cuts fuel if you roll, can always re-start if you roll back onto wheels, not sure how.much of a delay could be put in. Then fit a flap to the snorkle that closes with an emergency pull handle.
Old November 14th, 2010, 11:26 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
I did put it in 5th and hold the brakes, that's when you see it launch forword. It was no use. I was in low though so in high it may have worked. It blew very shortly after that video cut out. It didn't last long.
I always brought the egt's down to around 600 before I shut it off. In the rocks, it really never got over 700.
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old November 15th, 2010, 10:04 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
Bad turbo seals is a really common reason for diesel runaway. Not that it was the case this time, but it's common.
IMO the intake air shutoff valve (cable operated) is the best solution. For the most part zero maintenance, no need to worry about refilling CO2 or fire suppression tanks, works even with no power and at any angle. The only time it wouldn't work is if you were unconscious, but unless you had some automatic system (which could fail itself) they all would have that failure point. And as mentioned, very easy to test periodically.
It would also work as an anti-theft device if left closed. An added bonus the others don't offer.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old November 15th, 2010, 11:48 AM
It is running on engine oil, not fuel.
Anyway, a butterfly in the intake does seem like the best answer.
Old November 15th, 2010, 11:53 AM
ajh
Andrew J. Hutton
So you know that the instant it inverts it's got enough engine oil to continue or are you guessing? If you cut the fuel as soon as it was over say 75 degrees (so in any roll, including one that you end up back on your wheels) is there still going to be enough engine oil available that quickly to continue the run-on?
(I am not saying an intake valve is not also needed, but this would be automatic and could also work in the event of a RTA where the driver is unconscious).
Old November 15th, 2010, 12:13 PM
defeyago's Avatar
defeyago
Santiago
Right! In the video I posted before in this thread first thing I did was cut the ignition but kept going. Only way I could stop it was putting in 4th gear, release clutch and step hard on the brakes. I was in LOW range on the video. 4th is much stronger than 5th.
Run away engines are sucking a LOT of air at the time and as I see it it would be hard to make something that stops the air from getting in the admission. It should have to be very strong and tight to hold the air out in run away conditions.
SANTIAGO
Old November 15th, 2010, 12:15 PM
I see your point. It would make sense to engage the intake air valve using the rollover switch as well. You could do this all for freeish with parts out of the junkyard.
Old November 15th, 2010, 03:08 PM
pendy's Avatar
pendy
jim pendleton
89'd90
Guess I need to cut off a throttle plate from a R V8 injected intake housing and weld it onto the diesel manifold for Bucky. So a cable will hold it open to run. Spring tension will hold it shut not the cable. After it comes over center the vacuum should hold it shut anyway?
Old November 15th, 2010, 09:27 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
That kill switch on my dash is a racing one. It kills the engine pump and every electronic on the car (masterkill).
Anyway, the last thing you would want is for the engine to turn off right when you roll over. Most flops can be driven out of. The video is evidence of that. The air stop would be by far the best option. I will be putting one in for sure (or Pendy lol.)
But, like I said earlier, I think if my engine was 100% it would not have had this happen. I have been over a lot. It was running like boo before this even happened.
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
300tdi, diesel, tdi
Diesel Upgrade: 300TDi vs 2.8TGV smenzel Misc. Chit-Chat 22 March 19th, 2007 08:29 PM
Bypass oil filtering on a diesel 300tdi or 2.8TGV? Chaucer Misc. Chit-Chat 1 July 11th, 2006 06:54 PM
300tdi diesel fueling control solenoid Chris Cox For Sale - Parts 1 January 2nd, 2005 07:22 PM
Diesel Conversion Experiences JimC Defender Technical Discussions 10 December 13th, 2004 05:22 PM
