Rubber Plug for Battery Compartment - Defender Source
Old June 6th, 2004, 12:41 AM
jbird
Justin Bird
94 D-90 ST
Does anyone know where I can find the rubber plugs (through which wires pass) for the battery compartment and the metal underneath the center console? I am referring to the plugs that are about an inch in diameter. Thank you.
Old June 6th, 2004, 01:12 AM
tbmcneill
Guest
Posts: n/a
A good hardware store often has them ... not talking about Lowe's or ACE, either ... normally locally owned single outlet or small chain.
T
battery, part, rubber
Battery Compartment under seat Flagg Defender Technical Discussions 11 May 15th, 2007 11:38 AM
Any issues with putting sound insulation underneath rubber mats? arbik Defender Technical Discussions 3 February 25th, 2005 02:27 PM
what does this plug in to? mattdh Defender Technical Discussions 6 November 2nd, 2004 11:59 PM
LR Glow Plug relay temp? dmarchand Defender Technical Discussions 0 June 9th, 2004 01:42 PM
Serial Link Mating Plug? Ramsay Defender Technical Discussions 9 May 13th, 2004 11:27 PM
