rubber is pealing off roll bars - Defender Source
Old April 30th, 2009, 10:01 PM
ditskovich's Avatar
ditskovich
dmitry
Range Rover Sport 2013
any idea how to fix roll bars with pieces of rubber hanging of it?
any places in VA or DC?
Old May 1st, 2009, 01:16 AM
specops1526's Avatar
specops1526
Beluga '97 90
When I had my hardtop on, one of the edges cut into the rollcage. I used some black roofing silicone (I think) to repair it. I got it at home depot. It came in one of those long tubes. It worked really well and you can't even see the damage.
Originally Posted by rijosho
Beluga 97 D-90
Chawton 04 DII SE
Tangiers 04 DII G4
Old May 1st, 2009, 08:25 AM
Brian, can you share some pictures of the repair?
I'd really like to hear what you come up with Dmitry and see pictures of the results. If I beat you, I'll do the same. I'm sure something like the Black silicone would do it.
Mine have some pretty good tears in them, and the PO had glued them with some clear glue which held up for a while, but is now no longer holding. I took the rear cage off last week so have no excuse but to fix mine up a bit.
Now mine has a few chunks missing as well, and Id love to hear if anyone successfully filled those without it looking like poo.
charles
Old May 1st, 2009, 08:43 AM
maybe this?
http://www.levineautoparts.com/pedaandvitop.html
charles
Old May 1st, 2009, 09:14 AM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
Which brings up another thought, what is the best product to use on the cage padding to prevent it from drying out and deteriorating?
~Scott T.
'95 D-90 ST - AA Yellow
Old May 1st, 2009, 01:06 PM
specops1526
Beluga '97 90
charles
Sure, I'll snap a pic tonite. It's a very small area. I think that silicone stuff I used is permanent so it was a good choice.
Beluga 97 D-90
Chawton 04 DII SE
Tangiers 04 DII G4
Old May 3rd, 2009, 05:26 PM
specops1526
Beluga '97 90
Here are some pics of the repaired area. It was a horizontal crack/tear in the corner.
Here's also a pic of the stuff I used. I thought it was silicone but it's polyurethane.
The repair was done at least 4-5 years ago.
ID:	19259   Click image for larger version
ID:	19261   Click image for larger version
Beluga 97 D-90
Chawton 04 DII SE
Tangiers 04 DII G4
Old May 4th, 2009, 08:56 AM
Thanks, I'll have to give that a go.
Old May 4th, 2009, 01:12 PM
specops1526
Beluga '97 90
No problem, good luck!
Beluga 97 D-90
Chawton 04 DII SE
Tangiers 04 DII G4
Old May 5th, 2009, 10:06 AM
Eric_S
Eric
'97 D-90 ST #1507
I like Aerospace 303. I use it on all rubber and plastic. Your local marine shop should carry some.
http://www.303products.com/tech/inde...TOKEN=60076492
roll bar, rubber
Rubber Gasket NAS 110 Roll Cage surf110 Defender Technical Discussions 18 November 26th, 2010 08:09 AM
Need Roll cage rubber feet protectors SOUTHPAW26 Defender Technical Discussions 6 August 22nd, 2008 06:34 PM
Angled Roll Cage Bars Replacement? mikemckay Defender Technical Discussions 1 May 16th, 2006 12:31 PM
95 Defender 90 frame and ST roll cage crobinson For Sale - Parts 6 November 24th, 2005 12:46 PM
Clamps for roll cage cross bars Ntajeep Wanted 1 June 20th, 2005 01:58 PM
