RU610313L - Sliding window rivet - Defender Source
Old July 22nd, 2008, 11:38 AM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
Anyone know the measurment of the sealed pop rivet for the rear sliding windows?
Part number RU610313L...
Old July 22nd, 2008, 11:48 AM
wow, I just used ones from home depot.
Old July 22nd, 2008, 11:57 AM
D90user's Avatar
D90user
steve
did you use the open back ones?
I was just worried about the seal. I'm not actually putting a window back in I'm putting a piece of aluminum to blank out the window for security.
Do you happen to remember wether they were 1/8 or 3/16... I'm near a fastner shop today and there is not a decent hardware store in Tahoe
Old July 22nd, 2008, 12:12 PM
No, I don't rememberthe size, sorry. They were just standard pop rivets - I havent had any problems at all with a seal. There is a rubber strip that covers them anyway from the outside, so I'm not sure how much opportunity they have to leak.
Old July 22nd, 2008, 02:48 PM
D90user's Avatar
D90user
steve
I will not have the rubber seal with the aluminum plates so I am a bit concerned about the open end. For dust more than water. If I cant figure it out I may just go open end and put some rtv in them.
Anyone know the size off hand?
Anyone know the standard body rivet diameter? (may pick some up to have around)
Old July 22nd, 2008, 05:00 PM
RyanS's Avatar
RyanS
Ryan
'93 NAS 110
I don't recall the size, but you can get open or closed end pop rivets from McMaster-Carr. I actually replaced all of my window frame rivets with screws/washers/nuts. This was after having one of the windows flapping on the side of the truck when about half of rivets pulled through the sheetmetal while driving down a washboard road.
Old July 22nd, 2008, 05:10 PM
D90user's Avatar
D90user
steve
Thanks for the tip Ryan. I think I will rivit for now though.
found this :
2.9mm x 5mmRA607096
1/8" x 3/16"RA608126
1/8" x 1/4"RA608176
1/8" x 5/16"RA608236
1/8" x 3/8"RA608253
Closed End Type
1/8" x 3/8"RU608123
1/8" x 1/2"RU608313
3/16" x 5/16"RU612123
Old July 22nd, 2008, 07:17 PM
RyanS's Avatar
RyanS
Ryan
'93 NAS 110
Steve - Don't know what kind of access you have on the inside (I've been running without interior trim for quite some time), but I'd recommend putting a washer on the sheetmetal side before you set the rivet. They sell washers specifically for pop rivets. This will spread the load and prevent pull-thru on the sheetmetal.
Old July 22nd, 2008, 07:55 PM
D90user's Avatar
D90user
steve
Great suggestion.
thanks Ryan.
Old October 7th, 2013, 09:54 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Bringing back this thread because I'm fixing rattling windows soon and thought about using countersunk head (also called flat head) rivet instead of dome head. The finishing rubber strip will fit much better.
Anyone done this ?
Cheers
- Charles Eames
window
Station Wagon 90 110 Sliding Rear Window Fixing Thread R. Kurk Defender Technical Discussions 39 January 30th, 2013 09:58 PM
Removing rear sliding window from pickup cab dave_lucas Defender Technical Discussions 2 October 31st, 2009 07:49 PM
Passenger side sliding rear window for a 90 or 110 roofside and one fixed window evilfij For Sale - Parts 2 June 2nd, 2009 10:46 AM
'97 blower switch, sliding window locks xrover Wanted 0 November 18th, 2008 08:56 PM
shattered sliding window on d-90 prospector Defender Technical Discussions 5 January 16th, 2005 10:41 PM
