rte radius arms causing axle to foul panhard bracket - Page 2 - Defender Source
Old July 30th, 2014, 10:54 PM
Arcadeus's Avatar
Arcadeus
Mark Bichin
97 NAS Station Wagon LE
I can't imagine anyone running a 5 inch lift and 37's...
That's what those arms are designed for... You need 3deg correction...
Old July 30th, 2014, 11:04 PM
umm, ok, so why did you get 5" arms?
put down the ganja dude.
Old July 30th, 2014, 11:08 PM
ganja?
Old July 30th, 2014, 11:11 PM
So Rasta man!
Old July 30th, 2014, 11:14 PM
It was lifted before and had less caster than spec. Now it has more, and not by a lot. Drives fine. Is there some quantitative justification for these comments or is this more of a "it's not factory therefore it's bad" approach? (which is ok...just trying to understand.)
I'm all for staying factory, but some folks are running 0 degree caster on 2 inch lifts on stock radius arms with their pinion pointing straight at the output shaft of the transfer case. I think that this is an infinitely more dangerous situation than running a few more degrees of positive caster...
------ Follow up post added July 30th, 2014 11:14 PM ------
Originally Posted by Rocky View Post
So Rasta man!
Dave just needs more of what I'm smoking
Old July 30th, 2014, 11:25 PM
Arcadeus's Avatar
Arcadeus
Mark Bichin
You don't need castor correction with 2" lift... You do when you hit 3"
Old July 31st, 2014, 12:10 AM
The extra positive caster will make the steering less responsive moving forward and more likely to come around on you when reversing down a steep slope.
A degree or two less caster than stock doesn't seem to make a difference. Front diff always points at the transfer case, that's how the trucks left the factory.
Old July 31st, 2014, 09:10 AM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Ed, perhaps this could help in establishing the proper angles.
ID:	99773   Click image for larger version
Old August 3rd, 2014, 09:47 AM
hahah! obviously my issue is that my diffs are in the wrong place
Old August 3rd, 2014, 06:37 PM
Arcadeus's Avatar
Arcadeus
Mark Bichin
im far from "its got to be factory" as you can tell by my truck.... all im saying is that at 2" of lift you really dont need any correction, at three it becomes a good idea... but when you go 6 degrees castor correction at two inches of lift you rotate the diff far enough that you start doing things that the makers of the arms didnt account for.... because they were designed for 5 inches of lift... at that amount of lift with those arms you wont hit any brackets
Old August 5th, 2014, 01:35 PM
thank arcadeus. i am specing an additional 1.5" of lift. if i can't find an appropriate 3-3.5" lift spring, then i will have to roll my own using either tf023v or other rear spring.
i just want to say that the amount of lift is irrelevant. with these arms, the fouling occurs way before the bump stops are engaged. so unless the five inch lift prevents the bump stops from being engaged i think this would be an issue for everyone
that said, i have cut off the interfering tab at the axle and am sourcing an offset panhard as well.
Offset Radius Arms and Rear Trailing Arms OBXrover Wanted 0 September 28th, 2013 01:36 PM
WTB RTE Offset Radius Arms Hammertime Wanted 5 September 7th, 2011 08:47 AM
Rte radius arms crown14 For Sale - Parts 8 March 14th, 2011 10:38 PM
Bolt size for Radius Arms and Rear trailing arms Rugbier Defender Technical Discussions 5 May 29th, 2009 10:23 AM
Radius arms or trailing arms sflash868 Defender Technical Discussions 12 May 28th, 2006 05:40 PM
