RRC won't start without ether sprayed n2 plenum? - Defender Source
Old June 23rd, 2016, 11:47 PM
cowboy
steven
'84 110 & '90 127 LHD 2-carb V8's
Semi-local '90 RRC's seller seems to be saying it won't start without disconnecting the hose between the MAF & plenum and spraying ether into the plenum, but it only runs for a few minutes. Anybody have a clue as to what no-start condition could get a temporary fix with this method? - the tow in from the sticks to my place where I can tinker with it would cost me more than he's asking for it...
Old June 24th, 2016, 07:37 AM
Dead fuel pump, fuel pump relay, blown fuse, clogged line, or disconnected wires.
Old June 24th, 2016, 08:08 AM
Or the main relay that sends the signal.power to the fuel pump relay. The two are side by side under the passenger front seat. Rovers eat fuel pumps. If you turn the key on (run position)its should buzz for 10 secs and stop. If it doesn't, replace with know good ones, if it still wont run, then its the pump.
Old June 24th, 2016, 08:57 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
On the older RRCs, the top of the fuel pump assembly was metal and the ground wire would corrode and fall off!
I've had 2 trucks that did this. Regrounded, fuel pump came to life, truck started.
Just one more thing to look for.
I dont remember if a 1990 RRC has the fuel pump access door in the floor or not as a rule....some did, some didn't.
Rent my
Old June 24th, 2016, 12:59 PM
cowboy
steven
Ugh, seller edited his ad to SOLD overnight - I guess a $500 semi-running RRC within an hour of an I5 edgeburb can still get snapped up same day.
Thanks very much for the prompt replies, tho - I have zero experience going diy on fueling issues, so will definitely bookmark to my "no start" RRC folder! - still a '91 RRC daily driver guy for the time being...
One lingering question: is spraying ether into the plenum on these a legit way to help diagnose a no start situation? Is there a downside?
Old June 24th, 2016, 03:25 PM
Timing may be slightly off as well. Buy first, ask questions later.
start
wiper arms don't start moving without a nudge cgalpin Defender Technical Discussions 14 April 6th, 2011 07:50 AM
Won't crank, Won't start. revor Misc. Chit-Chat 4 September 16th, 2010 09:48 PM
D-90 stuck in Park, Won't start. HELP!!! brianosaurus Defender Technical Discussions 9 December 12th, 2007 09:45 AM
