RRC trans Out put shaft. - Defender Source
Old June 6th, 2016, 07:43 PM
ron's Avatar
ron
Ron
1994 NAS Defender 90
Smile RRC trans Out put shaft.
RRC trans Out put shaft. I am using a built RRC transmission and a 1.2 NAS defender transfer case and having issue matting the 2..
The out put shaft on the RRC trans seems to be running out of spline or bottoming out...
Any one have any ideas.....
very frustrating.....
Thanks all
good luck with your search
Old June 6th, 2016, 07:52 PM
One Ten's Avatar
One Ten
Sam
1994 NAS SW
You need a shaft like this with splines all the way down:
Land Rover Discovery 1 2 Transmission Tail Piece Output Shaft Coupling | eBay
The older style shafts didn't get the splines machined all the way down.
Old June 6th, 2016, 10:30 PM
ron's Avatar
ron
Ron
thanks that is what I figured only ffd with it for an hour... grrrrrrr.
so any thing above 1996 should work ????
Old June 6th, 2016, 10:44 PM
surprised that this is your first rodeo
Old June 6th, 2016, 10:55 PM
ezzzzzzz
Mark Garrenton
Common overlook. I've got one here that was gifted by Charles Galpin. PM your address and I'll send it on to you for your project.
I need to go back to work for the break. Retirement is exhausting!
'71 IIA 88" LS1 hybrid
'84 110 5 door 'Nigerian Princess'
'90 RRC
'97 D1 LSE (parting out)
'02 D2 Kalahari
'02 D2 SE
'02 D2 SE
Old June 7th, 2016, 11:14 AM
ron's Avatar
ron
Ron
Doug I have never dealt with the RRC .,...
I usually try and take a complete drive train.. But since I am doing a 4.6 and an auto conversion I had do a little mixing.... In the back of my mind I knew there was a difference but refused to accept it. : )
mark PM sent thank you....
93 NAS 110 cuts out when put into gear l*factor Defender Technical Discussions 18 June 11th, 2014 06:38 PM
Parting out 1991 RRC SWB & 1993 RRC LWB. Erik@Lucky8 For Sale - Parts 0 November 7th, 2013 10:43 AM
While the engine & trans are out, what else would you do? Davis Misc. Chit-Chat 4 February 22nd, 2010 10:35 AM
Take out V8 engine and trans--complete evilfij Wanted 9 June 17th, 2004 06:00 PM
Auto trans output shaft extension needed JCRover4x4 Wanted 1 June 15th, 2004 10:10 PM
