RRC trans issue, or? - Defender Source
Old March 30th, 2015, 08:02 AM
It's Always Something Dept.
Yesterday I drove the '88 RRC up to NJ to put on the ARB bumper that I left here last year, and pick up some parts that I traded to someone out in CA.
With the bigger (32") tires on the RR it sometimes takes a kickdown to 3rd to get up a long hill. Only on this trip it seemed to require more than usual. It got worse around Philly and then something started making a whining or whistling sound on acceleration only. I thought maybe a plugged cat, but the two fronts check out 6-700 degrees with the IR temp gun and the rear is about 400 so I think they are ok.
I noticed a few times it seemed like the trans was slipping i.e road speed did not match the gear and rpms.
Trans fluid seems ok, not burned and if anything a little high.
Engine compression tested last night was good around 150 all across and 165-170 wet.
Changed the fuel filter. Electrics/EFI are mostly new or redone as I am constantly working on them. No starting issues, usually fires off on the first crank or two.
I'm worried that running at 3k rpm in 3rd gear for some longer hills (5 minutes here and there maybe 10 at the most) may have damaged something.
Or that I succeeded in wiping the new cam, though I don't imagine that is the issue given the slippage, and the good compression results.
Also it seems to up shift to second way too early now. And it takes a long time to get up to speed from a stop.
Did I mention the whistling?
There is a Toyota pickup here possibly available to borrow that runs and drives. Though it is missing the sway bar.
I have a shitload of tools on board so taking a train back to DC isn't an option.
Any ideas or suggestions how to move forward here?
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old March 30th, 2015, 10:47 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
When I first bought my 97SW the trans was sluggish, constantly kicking down and awkward IMO. I thought it was just me going from a 5speed ST to an auto. Turned out there was too much trans fluid. Flushed and replaced and things improved nicely over time.
Clay
Old March 30th, 2015, 10:52 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
This is your low mile Classic?
You know if there was ever any service to the ZF?
Maybe just drain and refill making sure the level is correct.
Rent my
NPT90's Avatar
NPT90
JT
D90 óriginalé
I had a 4.0L Jeep that had some transmission shifting issues that were resolved with a throttle position sensor. Not sure if the LR engine has this component but it was a similar vintage.
Old March 30th, 2015, 08:30 PM
This was plugged cats. All better now. Just had to spend a few hundred bucks and listen to a stream of racist comments.
ID:	117253   Click image for larger version
Present:
1987 RRC- "Chewy 2"
Past:
Old March 30th, 2015, 09:26 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
^^ He's cutting without gloves or proper eye protection...tsk tsk. ^^
So, did you get replacement cats or just gut them? (meow!)
So after seeing a trans thread this morning I decided to drain and refill my diesel ZF(of unknown history) since it was so nice out this afternoon
Rent my
Old March 30th, 2015, 11:14 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
Welcome to NJ... I kid I kid!
you coming to the Wed meet up or headed home?
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old March 31st, 2015, 12:43 AM
I am back in DC. The truck runs great, lots of power now. 4 out 5 Maryland State Troopers agree.
Present:
1987 RRC- "Chewy 2"
Past:
Parting out 1991 RRC SWB & 1993 RRC LWB. Erik@Lucky8 For Sale - Parts 0 November 7th, 2013 10:43 AM
Trans line kit from AB: RRC 3.9/4.2 o2batsea For Sale - Parts 3 March 18th, 2013 07:54 PM
95' RRC No Start Issue Wolf Fabrication Defender Technical Discussions 16 November 2nd, 2012 02:39 PM
95 RRC goodies (some DI & RRC crossover) RoverDude For Sale - Parts 4 August 24th, 2010 03:19 PM
trans filter change question J4hand Defender Technical Discussions 0 December 17th, 2003 11:58 AM
