RRC Suspension Question - Defender Source
Old May 23rd, 2013, 02:59 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
My buddy has a '92 County that he purchased several years ago and is finally getting around to working on and driving soon. He wants to give it a mild lift with some tough looking tires, but doesn't want an all out Off-Road Rig as it will spend the majority of its time On-Road and he wants his wife and three kids to be able to get in it and be comfortable too.
Is there a 1" lift available (OME MD Maybe)?
What size Tires can you fit on it with a lift like this? What size tires and what lift do you all recommend?
Thanks in advance!
Old May 23rd, 2013, 03:08 PM
Simply installing a set of 235/85R-16 tires should give him the stance he is looking for without giving the kids nose bleeds. No other modifications needed.
As for tire selection, a very good choice is the Goodyear DuraTrac. Looks good, performs well, doesn't cost the moon, available.
The stock coil springs give a very plush ride. I wouldn't do a thing, 'cept maybe install a set of Bilstein shocks front and rear.
Alternately a set of spacers under the springs, like 1/2 inch or so, will also help with a slightly more aggressive appearance.
Old May 23rd, 2013, 03:15 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Thanks for the suggestion, that may be the way he goes. We were looking at the 265/70/16 or 265/75/16 (I forget which) Will there be any clearance problems with these and just a spacer? He would really like a wider, beefier tire. This started as he needs bushings and shocks (or at least wants to replace them all) but you make a good point, the springs are fine as long as the tires he chooses will fit.
Old May 23rd, 2013, 03:17 PM
All of those tire sizes will need cutting to clear.
http://www.rangerovers.net/rrupgrade...hes/index.html
Old May 23rd, 2013, 03:22 PM
265s you will have to put on taller springs, which means caster corrected radius arms, cranked trailing arms, long shocks, probably longer brake lines,blah blah blah....
Also, those wider tires do not help the handling characteristics. They will rub at full lock so he'll have to readjust the steering stops. It's not an F250 fer crissakes. They are made for skinny tires.
Old May 23rd, 2013, 03:26 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Haha, I know what you mean, he just likes a little wider tire. Is there a 255 that will fit? He definitely doesn't want to get into the castor correction etc. something more mild than that.
Old May 23rd, 2013, 03:29 PM
Others may disagree, but to my thinking 235 is the limit before going all-in with the suspension remodel.
Old May 23rd, 2013, 06:32 PM
Frank84
Frank Battersby
95 D90
Even a 235/85 will rub at steering lock pretty good unless you adjust the stops. A 265/75 will be worse. I'd actually suggest a 245/75 for someone going mostly for looks - doesn't rob as much power as the 235's and 265's since it is an inch shorter than those. And no need for any suspension mods for the 245, but if he does lift it an inch or two it will still look appropriate.
'95 Soft Top
'89 Classic Tdi
Old May 23rd, 2013, 08:40 PM
It will be a pig with 235's they will kill your turning radius. 265's are even worse.
245/75's and OME MD's of HD's are cheap and easy.
Old May 23rd, 2013, 08:48 PM
LRover's Avatar
LRover
J. Michael McCaig
Yup. I've run the 245/75 on Classics for years and it is the best size without going crazy on a lift. You can go with the OME lift and not have to do other mods like radius arms etc.
Old May 23rd, 2013, 09:42 PM
To save more money, put the stock rear springs in the front and OME MD in the back.
Old May 23rd, 2013, 09:45 PM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
I like the 255/65r16 on stock springs. Plus I get them freeeee
OME Suspension Upgrade - Question about rear sprongs DNinety Defender Technical Discussions 12 December 9th, 2010 08:20 AM
Suspension Question (swap from my RRC to the 90) AggieD90 Defender Technical Discussions 7 January 15th, 2008 07:29 PM
Another suspension question Joe P Defender Technical Discussions 1 March 15th, 2005 02:30 PM
suspension question - Scorpion asator Defender Technical Discussions 25 October 10th, 2004 12:24 PM
Rear Suspension Question dnewman9 Defender Technical Discussions 3 February 1st, 2004 06:31 PM
