RRC Radius arm issue... - Defender Source
Old June 11th, 2015, 12:05 PM
Gabriel_Laconi
Gabriel
1992 Rangge Rover
I know its not a defender, but some of these components are the same, so I was hoping that somebody might be able to point me in the right direction...
I installed what I was told are 3* corrected radius arms on a Range Rover with 3" lift. I noticed some vibrations and noises, so I decided to investigate ( and seal the swivel balls while I was at it...) anyways, after removing the tires I noticed the front axle was being pushed too far forward, to the point that the springs were not sitting right anymore.
You can see the gap on the top of the spring here...
Are the radius arms over correcting the caster? did I get 6* instead of 3?
Thank you for your help...
Old June 11th, 2015, 12:07 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Those look super corrected for 3 degrees...though it could be the angle. Here are my 3 degree arms(also by RTE)
Old June 11th, 2015, 12:36 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
I too was thinking they look like 6* arms. What springs are you running?
Old June 11th, 2015, 12:37 PM
Brett nailed it. Those arms are definitely not 3 inch arms. They look like arms meant for a 6 inch lift or more. Huge offset.
Back to your question about the axle being moved forward:
My RTE arms are also slightly longer than stock, which moves the front axle forward slightly, causing the springs to lean a bit like yours. Seems like a common thing for RTE to do. However, the distance that your arms have moved forward are at least an inch further forward than mine.
Some say that it's related to the amount of lift that a person has on their truck, but I'm not sure I buy that completely.
Old June 11th, 2015, 12:42 PM
Gabriel_Laconi
Gabriel
1992 Rangge Rover
Im running Old Man Emu 3" lift heavy duty...Looks like I need to find some one who wants to upgrade their 3* arms to 6*...
------ Follow up post added June 11th, 2015 12:44 PM ------
Here is a better view of the arms...they look nothing like the 3* on your picture...
Old June 11th, 2015, 01:07 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Sweet lord those are massive... definitely 6 degree.
You have no option now except to get some 5-6" springs
Old June 11th, 2015, 01:25 PM
Gabriel_Laconi
Gabriel
1992 Rangge Rover
LOL!!! Right. I have no interest in going that big...I will be posting them for trade here before too long.
Old June 11th, 2015, 01:28 PM
I think RTE will take those in for cores and give you the correct sized arms at a discount.
It's not the cheapest alternative, but it is an alternative. Shame someone sold these things to you saying that they were a 3 inch lift.
Old June 11th, 2015, 01:34 PM
Gabriel_Laconi
Gabriel
1992 Rangge Rover
I don't think he knew the difference...I emailed RTE but no reply yet...
Old June 11th, 2015, 01:43 PM
Holy beagle pups! You're ready to go muddin' down south!
Mark Kellgren
KM4BOR
Old June 11th, 2015, 01:54 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
As you push the axle down with lift springs it swings towards the back of the truck. The cranked radius arms are lengthened to account for this and keep the axle centered with the lift.
Old June 11th, 2015, 01:55 PM
Gabriel_Laconi
Gabriel
1992 Rangge Rover
Yes, but I only have 3" lift, these arms are over kill...
Old June 11th, 2015, 02:07 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
Yeah, I'd say. :D
Old June 11th, 2015, 02:32 PM
This guy might need a spare set. Contact thinair4x4@crazylift.net
Mark Kellgren
KM4BOR
Old June 11th, 2015, 04:37 PM
Call them...email is too slow.
Old June 11th, 2015, 05:01 PM
SLO Hybrid's Avatar
SLO Hybrid
Nathan Harrison
95 25th RRC/94 LWB /04 L322/87 RRC
You want to sell them outright?? I have many stock front arms you could use for a core @ RTE???
Old June 11th, 2015, 05:33 PM
Of course it is. That is the reason they make them. Brett can explain it to you.
Ding Ding Ding! What he said.
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old June 11th, 2015, 06:04 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
3 degree usually work up to 3" lifts
6 degree are for 3+ lifts.
IF you are running like a 6" lift then you are on your own!
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Radius arm and trailing arm nut size dave_lucas Defender Technical Discussions 3 February 25th, 2010 04:44 PM
radius arm torque jimmy salmon Defender Technical Discussions 3 May 26th, 2007 12:13 PM
Slotted Radius Arm Bushings -- Opinions? LRNAD90 Defender Technical Discussions 7 June 19th, 2006 11:37 AM
SG and Hinged and pinned castor corrected radius arm Shane@EVS For Sale - Parts 5 March 21st, 2006 11:20 AM
For Sale: Mantec Steering Guard, NSO Rear Shock Mount, Hinged Radius Arm Doogs For Sale - Parts 8 January 26th, 2005 11:28 AM
