RRC non-ABS: can you lock brakes? - Defender Source
Old May 30th, 2005, 03:08 PM
artm
Arthur Maravelis
97 SW
Well, I finally got around to replacing the ABS from the RRC LWB with regular vacuum setup.
Doesn't feel right and I can't get it to lock. The truck stops OK, even abruptly but not on a dime.
FYI, I kept the LWB dual line fronts and simply fitted the servo and MC from an 89, also with dual fronts. The two lines going to the rear were joined in the enigne bay with a T basically duplicating the RRC without ABS.
So, if you should be able to lock a RRC non-ABS and I can't then something's wrong. I also get the red brake lamp come on and off indicating bad pressure so something's up.
And I thought this would be a piece of cake!
Oh...when you do lock 'em do all four lock, ideally? I would think so.
Old May 30th, 2005, 07:13 PM
Yes, my 88 would lock all four.
brake
RRC ABS pump TanDisco1 Wanted 7 November 17th, 2008 01:59 PM
Door Locks Don't Lock ronward Defender Technical Discussions 3 August 27th, 2005 04:57 PM
1991 RRC FS. Lots of New Parts. Mike M For Sale - Vehicles 4 February 14th, 2005 08:16 PM
DII LT-230 in Old RRC, HELP Please. RedRhinoProducts Defender Technical Discussions 1 November 6th, 2004 02:24 PM
diif lock inquiry rover4x4 Defender Technical Discussions 16 February 6th, 2004 07:35 PM
