RRC Ignition wierdness - Defender Source
Old February 28th, 2016, 03:25 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Getting the lwb buttoned up and it's decided that it doesn't want to start ("Ran when parked!") A PO installed, poorly, a battery maintainer that is somehow wired through the alternator. It now cranks but doesn't catch and, here's the truly strange part, if I take the key out of the ignition, the interior lights and the battery warning light will stay on until the battery is disconnected. Also, the alternator is new and the tach doesn't work.
While there may not be causality between the battery maintainer and the no-start, I would like to ensure that the wiring is correct at the alternator, amplifier and coil. Does anyone have a cheat sheet on what goes where? the Manual isn't proving to be helpful.
Many thanks in advance.
Old February 28th, 2016, 06:25 PM
Did it start before?
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old February 28th, 2016, 09:27 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Yup, ran well
Old February 28th, 2016, 10:09 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Picture of my '91, I think its the same for lwb
Rent my
Old February 29th, 2016, 06:55 AM
Abrooks's Avatar
Abrooks
Tony Brooks
Thanks Jeff, what post do they go to?
Old February 29th, 2016, 07:35 AM
drdread's Avatar
drdread
AL
'94 NAS 90 SW
Not sure what year you have but my '94 did something similar and it turned out to be a cut off switch I accidentally depressed under the drivers seat. Idk if that's standard or unique to mine but thought I'd throw it out there besides the obvious started, ignition and battery stuff
1994 Silver DEFENDER 90 NAS SW
Old February 29th, 2016, 07:38 AM
Do you have the Marelli alternator? The white wire is the tach wire and goes on the spade terminal (looking at the back of the alternator it is the one on the far left). The brown wire is the alternator charge lamp on the dash which is connected to the small stud terminal (middle), and the big fat brown wire is the battery connection (right).
Old February 29th, 2016, 09:44 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
^ yep- what Bill said ^
Mine is a picture of the Tillery H.O. alt but it wires up the same.
Rent my
Old February 29th, 2016, 09:53 AM
white tach wire has a blade type connector, and brown charge lamp wire has a ring connector held on by an 8mm nut to keep anyone from messing up.....
Old February 29th, 2016, 09:45 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Things are starting to reveal themselves. There is no white wire going to the alternator, and I can't find one hanging out immediately -- that will need some research. That accounts for the no tach issue. On the no start issue, the white/black wire going to the coil separated itself from the coil at the spade connector when I looked at it funny. That could well be the no-start issue. I'll reconnect in the daylight and see what that yields.
Anyone know if that ignition suppressor actually does anything?
Old March 4th, 2016, 03:56 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Success! Found a wire that had broken in the spade connector at the coil, fired right up. Battery light and interior lights still stay on with key removed, though. And ideas on that?
Old March 18th, 2016, 04:59 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Next step: find alternate wire. Can someone trace the white wire from the alternator back and tell me where it physically goes? I've unwrapped the bodged harness that the PO created in the installation of a battery minder and I'm trying to get it back to stock.
Thanks!
Old March 20th, 2016, 08:37 AM
Abrooks's Avatar
Abrooks
Tony Brooks
Bump
RRC SWB 95 LS Gen IV Build :: 1995 Land Rover RRC SWB SGS714 Defender & Series Truck Registry 5 April 25th, 2016 07:31 PM
95 RRC LWB White 300tdi :: 95 Land Rover RRC SGS714 Defender & Series Truck Registry 0 November 14th, 2015 09:26 AM
WTB 92-94 RRC Ignition switch brn24whl Wanted 7 January 30th, 2014 08:54 AM
Parting out 1991 RRC SWB & 1993 RRC LWB. Erik@Lucky8 For Sale - Parts 0 November 7th, 2013 10:43 AM
95 RRC goodies (some DI & RRC crossover) RoverDude For Sale - Parts 4 August 24th, 2010 03:19 PM
