RRC Fuel Pump Installation - Defender Source
Old December 31st, 2015, 06:03 PM
belgian's Avatar
belgian
Maxim
1995 RRC SWB
Ok,
I have officially inhaled gasoline vapors for 2.5 hours, and I need help. (If I even get close to the fireworks tonight, I might explode)
I bought a 92 RRC with a bad fuel pump, after addressing the wiring issues, I hooked up the new fuel pump outside the tank, and it works great.
However, when installing the new fuel pump in the tank, I can't get the red locking ring to completely lock. Is this normal that this is a challenge? Or am I doing something wrong.
The fuel pump sticks out a little, which just like the previous pump, I can press down, the seal seems to be depressing right, but when I get the locking ring on there, I can get it to tighten, however, it seems like it doesn't follow the threads right, and eventually it pops right up. ( Especially if I try to tighten it to much.. which is obviously not normal since it took me forever to get this locking ring of). The threads however, on both the fuel tank, and locking ring are still great...
Can you guys look at the pictures, and see if the seal is on there right? or if you see something wrong?
I'll try again tomorrow, but I'm wondering if this is supposed to be a challenge?
Thanks!
ID:	138278   Click image for larger version
ID:	138280   Click image for larger version
1984 Camel Trophy 110
1995 Range Rover Classic SWB
1992 Range Rover Classic SWB
Old December 31st, 2015, 08:17 PM
Mtanzania
Frank
1994 D1 300tdi - Sold :-(
It can be difficult to get the seal to press into the tank properly. The pump should be pretty much flush at the top of the 'spout' except for the small lip of the rubber seal...possibly the seal is getting fouled and you aren't getting the pump seated properly. Once it is fully seated, you should have no problem putting the locking ring on
94 D1 300tdi - Sold
93 LWB-Isuzu diesel 5 speed
Old December 31st, 2015, 08:21 PM
One Ten's Avatar
One Ten
Sam
1994 NAS SW
These are usually difficult. Put the rubber ring in the tank first. Put some grease on the inside of it and push the assembly in. You'll have to keep some downward pressure on it so it doesn't pop out while you put the ring on. Every time I do one I find it annoying
Old January 1st, 2016, 07:21 AM
belgian's Avatar
belgian
Maxim
1995 RRC SWB
Thanks Frank and Sam,
I'll definitely take both of your advise, and try again today.
I just assumed that this part would be very easy, and uneventful. I guess I was wrong.
Old January 1st, 2016, 08:47 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Temps are dropping here in VA today. Would any of these components benefit from sitting in warm water to stay pliable?
fuel, installation
RRC Fuel Pump JPRO576 For Sale - Parts 5 January 12th, 2014 12:28 PM
93 RRC fuel pump source milroy Defender Technical Discussions 4 November 6th, 2012 02:11 PM
TD5 Fuel Pump/ pump tomaco1 For Sale - Parts 7 September 20th, 2011 09:13 PM
feed 200tdi lift pump from Facet fuel pump ? kjva Defender Technical Discussions 1 September 7th, 2011 01:55 AM
95 RRC fuel pump relay location? phoenix37 Misc. Chit-Chat 9 December 5th, 2010 11:16 AM
