RRC brake pedal switch won't fit? - Defender Source
Old September 18th, 2015, 12:23 AM
cowboy
steven
'84 110 & '90 127 LHD 2-carb V8's
Having a hard time getting my new LR brand brake light switch (for ABS) to fit the square-ish hole on the brake pedal arm of my '91 Classic (with ABS). Already tore up the generic one that I tried from O'Reillys, is there a trick to this? I tried some silicone lube around the case...& tried to push fairly hard with needle nose pliers that turn 90 degrees at the tip (which makes for a fairly nice fit for gripping this part)...
Nothing Googled up re this issue, is there a trick to this that has been kept a secret from the internets? File down the tabs on the case, maybe? Something? Anything??? - Thanks for looking!
Old September 18th, 2015, 08:10 AM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
What part number are you using?
Old September 18th, 2015, 10:22 AM
cowboy
steven
Lr005794
Old September 18th, 2015, 11:30 AM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Odd...should fit right in. Have you tried any other brands?
Old September 18th, 2015, 11:51 AM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
This any good?
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old September 18th, 2015, 03:51 PM
cowboy
steven
Thanks, Roverman! - sliding out the red sleeve enables the retaining clips to bend inward enough to clear the opening, apparently. Part is in & brake lights now working. So much for trying to wing it...
brake, switch
Pressing brake pedal turns on parking and brake lights burlsube Defender Technical Discussions 9 August 28th, 2015 11:21 AM
Accessing Brake Pedal Switch Oxcart13 Defender Technical Discussions 2 August 21st, 2013 01:57 PM
Assembling engine--center main bearing won't fit Davis Defender Technical Discussions 1 March 30th, 2010 09:49 AM
Assembling engine--center main bearing won't fit Davis Defender Technical Discussions 0 March 20th, 2010 02:40 PM
Front brakes axle shims won't fit... thewap Defender Technical Discussions 6 June 7th, 2006 11:50 AM
