RRC alarm remote shot - Defender Source
Old March 5th, 2013, 03:18 PM
Baja 90
Raul
97 D90, 94 RRC
Hi guys, my 94 RRC alarm remote is shot. Can it be replaced by a generic remote? Anybody replace theirs? I called RN, they have one for 170.00....more than I want to spend.
Raul
Old March 5th, 2013, 03:40 PM
The remotes and the module are set at the factory. You can't replace it. Do you have the remote? Hope so. Maybe it just needs a new battery?
Maybe you have the later potato shaped remote and not the square one? If so then you can reset the fob:
Note: This process must be carried out in 8 seconds to access learn mode. Best done with two people. You should have both remotes available or the second one will not work.
Open hood and have assistant hold hood alarm switch down.
With all doors closed and lock knobs up turn the ignition key on then off.
Cycle drivers door button down then up.
Assistant should then release the hood switch.
Turn ignition on then off.
If done correctly, horn will beep once and dash LED will light up. This indicates the learn mode has been accessed. If this doesn't happen repeat 1 thru 6.
From inside car push and hold first remote. The dash LED should flash 8 cycles a second for one second, indicating that the code was received. If this does not happen repeat steps 1 thru 6 again.
Push and hold the second remote if the code is received the dash LED will flash 8 cycles indicating that the code was received. If this does not happen repeat 1 thru 7 again.
Note: Turning the ignition on at any time will cancel the learning process.
The system can only store two remote codes and must be done one at a time.
If you only have one remote, program it twice.
PS there are a bunch on Ebay for about $70. Still way too much, but hey....
Old March 6th, 2013, 02:53 PM
Baja 90
Raul
97 D90, 94 RRC
Thanks for the info! I have the original remote, the potato shaped one. I think it's just old. I replaced the battery and it worked for a couple of Weeks, then it just started getting harder and harder to get it to work. I figured the contact had just gone bad. Never thought they were that expensive. I'm going to open this one up to see if I notice anything.
Thanks again!
remote
95 RRC goodies (some DI & RRC crossover) RoverDude For Sale - Parts 4 August 24th, 2010 03:19 PM
RRC non-ABS: can you lock brakes? artm Defender Technical Discussions 1 May 30th, 2005 07:13 PM
Husky 10 with Warn Remote?? priest944 Defender Technical Discussions 7 March 31st, 2005 07:56 PM
DII LT-230 in Old RRC, HELP Please. RedRhinoProducts Defender Technical Discussions 1 November 6th, 2004 02:24 PM
'93 Defender 110 Winch Remote ember Wanted 3 March 28th, 2004 02:45 PM
