RR Classic Radio wiring diagram - Defender Source
Old November 10th, 2011, 11:49 AM
jjstahl3's Avatar
jjstahl3
Jay S
96 D1 TReK
so I have been riding in my 88 classic that is filling in till my 84 110 shows up and since the radio in it has long giving up working I picked up a replacement but anyone know what wires are in these 2 factory plugs? so I can hook up the replacement
thanks in advance
Name:	Photo Nov 09, 5 13 16 PM.jpg
Old November 10th, 2011, 02:30 PM
jjstahl3's Avatar
jjstahl3
Jay S
96 D1 TReK
photos for barry
any one know where I can get service on the cell phone?
Name:	Photo Nov 10, 11 22 19 AM.jpg
ID:	43576   Click image for larger version
Name:	Photo Nov 10, 11 22 03 AM.jpg
Name:	Photo Nov 10, 11 21 41 AM.jpg
Old November 10th, 2011, 02:39 PM
Yes, 1989.
Old November 10th, 2011, 02:41 PM
JohnC
Giampaulo Cinquegrana
95 DI SR Extreme Kit - 94 RRC LWB
thanks in advance
I can't see the end of the plugs very well but I had wired an aftermarket unit in my 88, let me see if I still have the wiring diagram or something.
John C.
Old November 10th, 2011, 02:54 PM
jjstahl3's Avatar
jjstahl3
Jay S
96 D1 TReK
that would be great - it had the factory head unit in it and had 2 cord bundles plugged in the back - I assume one bunch it the 8 speaker wires and the other bunch is power, accessory, ground, power antenna, etc but Im going to lose my mind if I have to go much longer without some music to drown out the noises this thing makes!
josh if you have access to a time machine please get me the 49.99 plan on the phone - thanks in advance
Old November 11th, 2011, 03:16 PM
PaulMc's Avatar
PaulMc
Paul McConnell
1989 110 2.5 Turbo-Diesel
thanks in advance
The connectors are RISTS TTS connectors.
The 9-way connector (8 pins used) is for the four speakers - front left and right / rear left and right.
The 5-way connector (4 pins used) has - permanent live, ignition-switched live, dash illumination and earth (ground).
I have some adaptor looms, that will plug into these connectors and convert them to the ISO standard -
ID:	43603 . Click image for larger version
ID:	43604 . Click image for larger version
PM me for details, if you're interested.
Paul.
Paul.
1989 Arles Blue 2.5TD 110 Hardtop
1999 Epsom Green Discovery II 4.0 V8i 'XS'
Old November 11th, 2011, 05:38 PM
jjstahl3's Avatar
jjstahl3
Jay S
96 D1 TReK
thanks to paul for the breakdown - if everything goes well getting out of work today and listening to music later tonight!
Old November 11th, 2011, 07:06 PM
On my classic that was a 91 it had two amps and 6 speakers. I was able to use the wiring diagram in the manual to remove the amps and bypass most of the wiring. I wired the speakers to the head unit with a pigtail. This is probably the best/easiest way to approach this. If you think it will help I can try to make a pdf of the wiring diagram in the owners manual. That being said only a Classic would have the entire wiring diagram included in the owners manual.
Im diggin that cell phone, is it 4G?
classic, radio, wiring
'94 NAS D90 radio wiring diagram? PTSchram Defender Technical Discussions 17 July 21st, 2013 07:41 PM
95 D90- A/C WIRING DIAGRAM (Davia) --> norros Defender Technical Discussions 30 July 7th, 2010 03:38 PM
A/C wiring diagram Shane@EVS Defender Technical Discussions 3 August 20th, 2004 08:46 AM
hella wiring diagram Campbell Defender Technical Discussions 1 May 1st, 2004 02:28 PM
300tdi Wiring Diagram? JimC Defender Technical Discussions 20 April 7th, 2004 09:39 AM
» Defender Registry
Annabelle
seabrook
248
xjahx
Add your Defender
