RR air suspension compressor for ARB? - Defender Source
Old August 16th, 2007, 10:45 PM
headdamage's Avatar
headdamage
Andrew
exmod 90 2.5na and a 93/RRC 200tdi
Sorry if this had been addressed before but if it was I must have been searching incorrectly. I have a couple of good conditon RR air suspension compressors in the garage and a new ARB diff. Has anyone used one of these to run an ARB locker or to build a limited capacity on board air system? Thanks for any info.
Old August 17th, 2007, 12:03 PM
Baldewin's Avatar
Baldewin
Chris Baldewin
Bastard 90
Andrew,
Very possible and a very capable compressor. You will need to install a pressure relief valve on it especially if you are running all of the Range Rover parts since they run at a high pressure than the ARB requires. Go to www.rangerovers.net and you can ge a ton of info there.
Good luck,
CB
compressor
In line blower for mantec raised air intake system LenB Smaller Projects 22 November 20th, 2009 08:24 PM
range rover air suspension issues ember Defender Technical Discussions 0 February 18th, 2005 01:56 AM
air suspension jimmy salmon For Sale - Parts 4 February 15th, 2005 03:38 PM
Air Suspension gtg067i Defender Technical Discussions 6 January 20th, 2005 10:16 PM
