rpm range - Defender Source
Old June 12th, 2006, 09:40 PM
mattdh's Avatar
mattdh
Matt Hurst
rpm range
just checking the rpm range for the tach.idels about 700-1000?shift about 2500-3000?is that right? mabe a little high on the shift.not sure
Old June 12th, 2006, 11:56 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Idle RPM should be pretty rock solid around 700-750rpm when warmed up, a bit higher when cold.
I normally shift in about that range as well, sometimes higher. Once in a while I leg it out to around 4500 or so, but that's as high as I am willing to go, and only when I REALLY need to get around that tractor-trailer.
-Hans
My oil line fix
My 100k stopped odometer fix
Old June 13th, 2006, 12:15 AM
mattdh's Avatar
mattdh
Matt Hurst
thanks again hans! 4500 the engine is scream? yes
Old June 13th, 2006, 12:33 AM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
Idle is automatically controlled to be between about 670-730rpm. The V8 makes peak torque at 3100rpm. According to my owners manual, the engine is designed to be operated between 2000-5000rpm. I try to drive at around 3000 rpm or a little higher if possible for power, cruise at about 2000rpm for more economy. I regularly shift above 4000rpm. I will boot it to almost 5000rpm on occasion. The engine redlines at 5500rpm, at which time the ecu will start to cut the fuel injection. If you're shifting at 2500rpm you're missing out on a good part of the power band of the engine.
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Famous Land Rover owners Lindy Misc. Chit-Chat 4 June 15th, 2009 08:49 PM
1997 Range Rover 4.6 HSE woldd90 For Sale - Vehicles 20 September 14th, 2006 09:43 AM
RPM Fluctuation Billakris Defender Technical Discussions 5 March 28th, 2005 10:52 PM
The latest show-stopper: dies at idle, only runs above 2K rpm jaherring Defender Technical Discussions 34 December 23rd, 2004 07:05 PM
