RPM Fluctuation - Defender Source
Old March 28th, 2005, 09:37 PM
Billakris's Avatar
Billakris
Kris
Alpine White 95 Soft Top
Question RPM Fluctuation
This is a new one for me. Yesterday 2nd through 4th gear had a strange rpm fluctuation. Whenever I was accelerating or climbing a hill, the rpm would go way up but not give me any power, then it would drop down to normal. It would go up about 1000 rpm more than it usually is at at the same speed and acceleration. There isnt any gear grinding or anything, but its almost like the gears are slipping because the rpm goes up but i actually loose power.
Any Ideas?
Thanks in advance
Kris
Old March 28th, 2005, 09:49 PM
Hmm sounds like a clutch problem.
Old March 28th, 2005, 09:57 PM
Billakris's Avatar
Billakris
Kris
I was thinking that too, and I did just replace the master cylinder, but it goes in and out of gear fine and there isnt any grinding. Am I missing something?
Kris
Old March 28th, 2005, 10:11 PM
I was thinking if the clutch was worn then it would do as you said. When under a good load it would slip, when it would slip the engine RPMS would go up and because it was slipping there would be less power transferd to the wheels
How many miles on your clutch? Is there any oder?
Old March 28th, 2005, 10:39 PM
Billakris's Avatar
Billakris
Kris
There isnt an odor, and the clutch has 73xxx on it. Any way I can test to see if this is or isnt the case?
Thanks again Mike
Kris
Old March 28th, 2005, 10:52 PM
Hmmm I have never had to test a clutch before, but if I had to I would hold the breaks while letting the clutch out, if it slips then you know you have problems, if it stalls then it may be good, if it slips then stalls still bad clutch.
I can't think of anything else it could be other then water and mud in the bell housing causing the clutch to act up, but when I replaced mine (had the engine out and found the clutch needed replacing so I replaced it) the Bell was full of muck, and the clutch felt fine when I drove it. It is a big pain to replace as you need to either drop the tranns and T-case or pull the engine out; the parts are not all that expensive.
Low RPM knocking, ideas? OCD90 Defender Technical Discussions 6 September 30th, 2005 05:14 PM
Engine sputtering chugging between 2650-3200 rpm Heath Defender Technical Discussions 14 February 8th, 2005 08:36 AM
The latest show-stopper: dies at idle, only runs above 2K rpm jaherring Defender Technical Discussions 34 December 23rd, 2004 07:05 PM
weird noise with higher rpm scubadanster Defender Technical Discussions 8 December 13th, 2004 07:32 PM
D-90 occasional missfire around 2000-2500 rpm Toddco Defender Technical Discussions 15 October 22nd, 2003 05:40 PM
