ROW TDI low fuel light - Page 2 - Defender Source
Join the Defender Source Community Today
Old September 9th, 2016, 08:56 AM
I guess I would trace the white/slate wire from the cluster then. You need to see where it goes and what is wrong.
Old September 9th, 2016, 06:23 PM
AdamSanta85's Avatar
AdamSanta85
1991 D90 SW
I am pretty sure you are right with this module.
I was fixing my not working diff lock today (adjusted linkage and turned switch out a couple turns, and she is working) and I decided it was a good opportunity to trace the wires, being that I had both floor pans, and tranny tunnel off.
Sure enough I follow the harness off fuel sender up the engine side firewall. I see the ground bolt to the upper bulkhead. I see the green and slate go to a harness, but wait! The green mates with another wire on the other side. The slate, there is no wire on the other side. The connector is blocked off. Nada. From the factory.
To double check I disconnected this harness and sure enough the fuel gauge goes to zero. Definitely the right harness.
So that means the slate is in fact not hooked up to anything and the green must be my low fuel light wire as well.
Once my new VDO gauges get here I will trace the wire behind the dash to find the module to see if I can find the problem. If not I will grab that one you linked (big help thank you!)
Alternatively I can run a wire to the slate/grey off the sender harness directly to the dash to create my own 3 wire setup.
The only other possibility is the dash warning cluster is screwy, but every other light works as it should so that is unlikely.
Old September 9th, 2016, 06:36 PM
AdamSanta85
1991 D90 SW
Looks like this one might be best for us as it can drive a conventional bulb vs an LED
High Output 12 - 24V Low Fuel Warning Light Module | eBay
Old September 14th, 2016, 10:39 AM
AdamSanta85
1991 D90 SW
Any help finding this module? I have my cluster removed to install new gauges.
I looked and looked, tried tracing the wires from the fuel gauge and from the low fuel light. I just looks like it goes into the main harness that runs towards the right hand firewall plug. I mean I can't get eyes on everything but it really doesn't look like there is any place for a module to be. If there is a module it is in a spot not accessible without removing the dash. If I can't figure it out I am just pulling the low fuel bulb for now, no time for something so trivial.
In Red90's photo I can see the ignition and bar behind the cluster in the background. It definitely isn't in this spot for me. I have full access to that area.
fuel, ht, tdi
Low Fuel Light always on Stmpede Defender Technical Discussions 3 April 5th, 2012 03:27 AM
low fuel warning light. jack SF Defender Technical Discussions 18 April 16th, 2011 11:28 AM
New ROW backup light and Fog light dave_lucas For Sale - Parts 2 June 2nd, 2010 07:38 PM
97' D-90 Low! Low! miles MRROVER For Sale - Vehicles 0 November 30th, 2009 08:54 PM
D90 low fuel waring light RoverC Defender Technical Discussions 6 May 26th, 2009 11:51 AM
» Defender Registry
Cash
gilby
#304
TRS
Add your Defender
