ROW chassis frame: wiring inside? - Defender Source
Old June 15th, 2016, 12:00 AM
DailyDrivenDefende
Michael
1989 110, 1985 90 200TDI
Hi guys,
I am getting ready to replace my rear cross member for my D90 ROW.
What function does the wiring in the right chassis frame rail do?
TIA
Old June 15th, 2016, 12:27 AM
One Ten's Avatar
One Ten
Sam
1994 NAS SW
Tail lights, wiper/heated glass in rear door
Old June 15th, 2016, 02:07 PM
DailyDrivenDefende
Michael
Do I need to undo the wiring on the tail lights to snake it back onto the new crossmember?
Old June 15th, 2016, 02:22 PM
seaswood
Diesel
If replacing involves welding you will want to pull those wires forward out of the way, I would think. Depending where the weld is. Wires are all color coded.
Old June 15th, 2016, 02:55 PM
Harness is for everything on the back of your truck, depending on how your truck is equipped. In order to replace just the cross member you would only need to unplug everything to get the wiring out of the way. If you are doing a cross member with extension's, Ie cutting off the frame rail on ea side you must be very careful not to cut the harness. You either need to remove it or be very careful.
Old June 15th, 2016, 08:13 PM
DailyDrivenDefende
Michael
I am doing the cross member with extension.
Now, I haven't been under it yet to study the pigtails on these lights, would these simply pull through the old frame rail?
I suppose I will have to cut a window where I can see these and pull these through.
How are these done on frame chassis swap?
Old June 15th, 2016, 10:11 PM
CDN38's Avatar
CDN38
Scott Pelly
2000 110 TD5
I have seen a few come from the UK where they tried to do the repair while working around the harness. Doesn't work. Wires get cut, and are re-attached with crappy splices, or worse, get melted from welding in close proximity.
Pull the harness forward out of harm's way. Lots of extra work, but like most Landrover things, short cutting usually comes back on you.
Old June 16th, 2016, 10:59 AM
DailyDrivenDefende
Michael
Ok. I will be cutting it up then pull it out, reroute outside with new cross member and solder or place quick water proof connector instead.
Old June 16th, 2016, 03:01 PM
broadstone's Avatar
broadstone
'84 CSW 90 '74 NADA III '97 CSW 110
I run a 4-6 long lines of mig wire twisted and taped together every 6 inches, tie it off to the end of the wiring harness and tape off really well to avoid it snagging. Then pull it back at least 2 feet away from where you are welding or pull out completely if doing other chassis repairs. Then once welded just pull back through. I would get the harness out of the way before cutting. There should not be any reason to cut another opening just to pull the harness out or back through when finished.
Patches are for Pirates and pants, not a bulkhead and chassis!
Old June 16th, 2016, 03:06 PM
CDN38's Avatar
CDN38
Scott Pelly
2000 110 TD5
Very sound advice broadstone
Old June 16th, 2016, 05:05 PM
DailyDrivenDefende
Michael
Ok. I have not crawled under the truck to figure this out yet but my question is, how do you pull the wires initially away from the spot you are cutting at? Do you pull it from the front of the vehicle? You do have to pull it from somewhere so that you can move the harness away from the spot you are cutting at. See where I am coming from?
Old June 16th, 2016, 05:21 PM
broadstone's Avatar
broadstone
Disconnect the wiring harness from the connections at the rear x-member (attach mig wire or other snake for the return pull once finished) and pull the harness out from the front where it enters the chassis.
wiring
What adds more value: early original chassis or galvanized chassis? nathanwind Misc. Chit-Chat 25 December 7th, 2012 09:49 AM
POR-15 the inside of the frame? Rufus Defender Technical Discussions 9 February 25th, 2011 12:43 AM
Galvanized Rear suspension a-frame to chassis mounting brackets dave_lucas For Sale - Parts 7 December 18th, 2010 04:52 PM
Where can I find the pads that go on the cage bar inside the SW? Pic inside... KKilo23 Defender Technical Discussions 6 June 26th, 2009 05:36 PM
110 frame or rolling chassis needs crossmember evilfij For Sale - Parts 9 May 2nd, 2009 10:11 PM
