ROW 110 with exploded front diff/axel housing - Defender Source
Old April 2nd, 2012, 04:15 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Alright, back at this issue now that I'm relocated.
Axel Housing is F'd, front diff carrier grenaded and took out the axel housing...
Opportunity knocking for a HD unit.
Best resource for a full replacement front axel housing with diff housing and internals in western Washington? (Closest big city is Tacoma)
Am I right in that i am after a D1 front axel/diff, or a pre 93 Classic front setup?
Thanks in advance for any and all help pointing me in the right direction...
Now planning on a full body off rebuild as soon as I can locate the big parts and rent a hangar to work in.
Old April 2nd, 2012, 04:28 PM
slorocco
Dan Prasada-Rao
1963, 109 Station Wagon
Don't know if you really want the pre '93 RR Classic axle. If I remember correctly, those are 10 spline axle shafts.
Old April 2nd, 2012, 04:45 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Check with Gord'n at www.lamornagarage.com/ in Seattle. If you end up building yours back up, get an 8" weld on pipe cap to replace the damaged sheetmetal cover.
Also, do you know if your '86 has the wide or narrow front radios arms?
-Jeff
Will reach out to Gord'n. The cover is not the damaged part, the lower bell has a few gear shaped protrusions (if I am understanding you right) so a complete axel housing is in order...
Not certain on the wide/narrow arms as this truck has seen some Central European repair work so its a little bit of a miss mash of parts...
Old April 2nd, 2012, 05:18 PM
Can you show us a picture? The lower bell is one of the thickest sections!
Pull a dust cap (you may need to pull a wheel if not running steelies) and count the splines and tell us what you currently have.
Originally Posted by pendy
I'm here for the D's
Old April 2nd, 2012, 05:31 PM
I have never had to drill out any calipers for the different bolt. What you talking bout Briggs ?
Also posted in the other thread what I do regularly.
Old April 3rd, 2012, 12:05 AM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Here are a couple images for you... note the bump slightly off center in the lower housing.
I pulled a cir-clip and a chunk of metal out of the drain hole.
ID:	49870   Click image for larger version
Old April 3rd, 2012, 07:24 AM
slorocco
Dan Prasada-Rao
Doesn't look bad to me, I'd keep it and run it.
Old April 3rd, 2012, 08:06 AM
I totally agree with Dan. Get a decent diff guard though - I recommend any weld on kind. The damage doesn't look bad enough to worry about future leaks even, but if you were, then get a sewer cap style which replaces the front cap completely. But even that would be overkill IMO.
I'd figure out what you spline count is and get a replacement third member and call it done.
hth
charles
Old April 3rd, 2012, 09:27 AM
This can all be sorted out for less than a hundred bucks.
Old April 4th, 2012, 08:03 PM
John_Karlsson
John Karlsson
1966 Series IIA 88 SW
If it is RHD, you might have some issues with steering linkages. Don't ask how I know....
John Karlsson
Hope Valley, RI
Old April 5th, 2012, 07:15 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Diff is blown, as there were chunks of gear teeth that I pulled out the lower drain hole... I can't figure out how to replace the gearing and damaged internal mounting points for less than a Benjamin...
------ Follow up post added April 5th, 2012 04:16 PM ------
Fortunately it's LHD, and I have located a complete replacement front axle and diff without having to resort to shipping.
Old April 5th, 2012, 07:18 PM
If it's 24 spline you just grab a complete 3rd member from a disco 1. Call Randy or Will, or maybe someone closer your way, or just visit a junk yard. If not 24 spline, ask here and someone will have one but you'll need to specify what.
Old April 5th, 2012, 07:24 PM
Charles,
He's on the wrong coast.
Old April 5th, 2012, 07:26 PM
To be clear you want one of these :
Doug, that's why I said someone closer your way. There has to be the equivalent vendors out west no?
Old April 5th, 2012, 07:46 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Attachment 49990
Plus the axle housing...
I found a local with the whole front axle housing, swivels, diff, for $500. Not sure I could do much better tracking down a junker or paying shipping from anywhere else.
Old April 5th, 2012, 07:49 PM
Sounds like a lot. I just sold a complete 110 10 spline front axle for $100... with brakes, but I'm known for being stupid cheap.
Old April 5th, 2012, 07:52 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
With diff/housing?
You are cheap, and on the wrong coast...
(That sounds far worse than I meant.)
Old April 5th, 2012, 09:46 PM
With diff/housing?
Is that like calling a female a dirty hooker ? Yep caliper to caliper, even included the radius arms.
Old April 5th, 2012, 11:16 PM
You don't need the housing!
Old April 6th, 2012, 08:40 AM
You'll get there sooner or later.
Salisbury 110 / 90 Front and Rear Axles for Sale SafariHP The Vendors Loft 0 July 4th, 2011 03:20 PM
Defender front seats installed in second row? discotdi Defender Technical Discussions 4 March 28th, 2011 09:12 AM
90 / 110 Front Wing Side Panels Wolf Fabrication Wanted 7 December 31st, 2009 05:47 PM
NAS 110 Front Roll Cage Aux light spacing (?) shawnpalmer Defender Technical Discussions 6 October 18th, 2007 09:52 PM
D-90 and 110 Front Rubber Mats Mike M The Vendors Loft 0 November 4th, 2004 09:39 AM
