ROW 110 with exploded front diff/axel housing - Page 2 - Defender Source
Old April 6th, 2012, 09:32 AM
Damn noddy, you are on fire this morning.
Brian, I do feel like there is a disconnect here somewhere. All you need is a third member and even if you shipped one coast to coast it surely would be a reasonable cost. That diff in the picture I posted was shipped in a bucket from Utah at a reasonable cost. So, for the last time, if you tell us your spline count, I am sure someone can help you get the right third member.
Originally Posted by pendy
I'm here for the D's
Old April 6th, 2012, 02:38 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
I do need the third member, and gearing. (pinion, bevel gear, cage, shafts, etc...) Technically the diff housing and cv/swivels are not the issue, but a full swap will be a lot quicker than dealing with parts problems as I go along.
Old April 6th, 2012, 05:46 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
No, the spline count on the diff side of the axle. That way all you need is a complete 3rd member.
Pull the 6 bolts that hold each swivel ball and slide the complete swivel assembly away from the housing. Once the ends of the axles clear teh side gears, you can remove the third member.
EDIT: On second thought, (after actually looking at the pic) a complete axle is going to be easier. The splines on the CV (and probably the drive flange) have excessive wear and need to be replaced.
-Jeff
Sorry I thought I posted a different pic, need to get a better handle on this whole Mac thing (recent convert) i-photo vs. image files.
Your edit note captures my intent a little more accurately. The truck has seen some "creative" repair over the years so I am inclined to take any opportunity to repair/replace parts with items that at least have a known history...
Salisbury 110 / 90 Front and Rear Axles for Sale SafariHP The Vendors Loft 0 July 4th, 2011 03:20 PM
Defender front seats installed in second row? discotdi Defender Technical Discussions 4 March 28th, 2011 09:12 AM
90 / 110 Front Wing Side Panels Wolf Fabrication Wanted 7 December 31st, 2009 05:47 PM
NAS 110 Front Roll Cage Aux light spacing (?) shawnpalmer Defender Technical Discussions 6 October 18th, 2007 09:52 PM
D-90 and 110 Front Rubber Mats Mike M The Vendors Loft 0 November 4th, 2004 09:39 AM
