ROW 110 fuel tank removal & replacement - Defender Source
Old March 28th, 2015, 04:56 PM
Jackie Treehorn's Avatar
Jackie Treehorn
A
1985 (legitimately)
So, after discussing part of this in Overlanders's NAS tank thead I figured I'd just start my own thread with my own specific issues.
First of all, I'll reiterate how incredibly flawed the manufacturing design is for these tanks with the seam just waiting to absorb dirt and moisture. I'll be packing mine with either Waxoyl or grease.
Okay, so my first question (which probably has a simple answer) is if my ROW deisel has the fuel pickup on the side incorporated with the sending unit, and the new tank has a pre-cut hole with eight (or is it six I can't remembers) pre-drilled and tapped holes for what I assume is the RRC fuel pump, is the rubber plug that comes with the tank enough to block that off or should I be screwing and mechanically fastening something on top?
Otherwise, the removal went very well with no hiccups except for a stripped hose clamp on the filler neck and of course a mangled retaining ring on the pickup. Surprised there weren't any issues with the mounting bolts, but all four came off without issue.
110, ac, fuel tank, fuel
NAS 110 fuel tank conversion steel to ROW plastic Overlander Defender Technical Discussions 13 March 28th, 2015 01:07 AM
Replacement Fuel Tank Needed Zoinks Defender Technical Discussions 2 February 9th, 2015 11:02 PM
110 Fuel Tank Removal moose Defender Technical Discussions 13 February 7th, 2015 11:35 PM
Wanted Long Range Fuel Tank Replacement Werrea Wanted 13 January 31st, 2015 09:48 AM
Transfer Case Flange Removal & Bolt Replacement mattarm Defender Technical Discussions 3 October 20th, 2014 03:01 PM
» Defender Registry
Wujek
bigkel162
Lola
Add your Defender
