ROW 110 200TDI First major failure... - Page 2 - Defender Source
Old May 28th, 2014, 06:15 PM
DannyboyUpstate's Avatar
DannyboyUpstate
Danny Harrington
1983 110 3-door
Originally Posted by Red90 View Post
If it has had a "less than professional" conversion.... You should check on other things..... Has the clutch housing been bolted into the ladder frame at the bottom? The Disco clutch housing is bolted through the flywheel on the Discovery, but that option does not exist on the Defender LT77 bellhousing and you need to add countersunk bolts. The "hack jobbers" don't do this.....
What suffix is the gearbox? If less than "F" plan for it to not last a long time.
I'm not sure exactly what you mean by this or where exactly the countersunk bolts would go. I see that little kit with the drill/tap/countersink is on that guy's site.
Here are pictures of my bell housing and flywheel housing:
Another new question: My flywheel has marks at approximately 9 3/8" across. The new clutch on Rovah Farm says it's 9 1/2" diameter. Are these the same?
Old May 28th, 2014, 06:35 PM
DannyboyUpstate
Danny Harrington
1983 110 3-door
OH! Another question: If you look at the picture of my engine bay you can see the heater cable hanging down. Is that the way that's supposed to be?? It seems like it's 2' too long.
Old May 29th, 2014, 12:01 AM
No it is not supposed to be that long.
------ Follow up post added May 29th, 2014 12:02 AM ------
Dammit. Totally could have used that information when I did my clutch! I *think* I'm already having issues with the crappy OEM bearing (2500 miles, <8 months).
Doh
Old May 29th, 2014, 06:01 AM
See the 4 holes at the bottom of the flywheel housing? Are they full of bolt or air? If the latter, then they need to be filled with bolt.
Old May 29th, 2014, 07:32 AM
DannyboyUpstate
Danny Harrington
1983 110 3-door
I'll look closer, but it appears to be air. There were two bolts through the transmission, which I think leaves 5 holes.
What's the purpose of these added bolts? Just extra rigidity?
110, 200tdi, tdi
Major Problem kennybahr Defender Technical Discussions 5 February 15th, 2008 08:31 PM
Major Wire problem-- dash dissasembly. Need help. Ignition Mallory Unilite Heath Defender Technical Discussions 22 August 29th, 2007 12:35 PM
major problem huck1974 Defender Technical Discussions 72 March 24th, 2007 05:15 PM
Radiator fins---- major corrosion bd90 Defender Technical Discussions 2 August 9th, 2006 11:27 AM
Major air! Mike Hippert Misc. Chit-Chat 4 November 9th, 2004 06:45 PM
