Rovertym springs - Page 2 - Defender Source
Old September 28th, 2005, 03:45 PM
johnlee
John Lee
Originally Posted by dmarchand
No Johnny boy. It's plain english. Lame.
Plain English? Help me out here. As a Korean immigrant, I don't seem to be getting it.
Exactly whom was David "representing", as you put it?
Old September 28th, 2005, 03:50 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Why, the shiny 2.8 powerstroke crowd.
Old September 28th, 2005, 03:52 PM
johnlee
John Lee
LOL.
Get a life.
Old September 28th, 2005, 03:56 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Originally Posted by johnlee
LOL.
Get a life.
Ah yes, as expected. Contributing to the discussions with your prowess.
Come back and see us again soon...
Old September 28th, 2005, 04:01 PM
is someone jealous??
Old September 28th, 2005, 04:16 PM
TwisteD90's Avatar
TwisteD90
Yousef Hamzeh
06 RR SC, 06 LR3, 94 D90
Oh carp, here goes John Lee again.
David, did you say 3-link??? Welcome to the dark side, but becarefull b/c your D90 will become a trailer queen
The A-arm extension should work but do not go over 1.5" other wise the diff will hit the skid.
Old September 28th, 2005, 04:38 PM
norros's Avatar
norros
Nicholas Orros
1995 NAS D90 SW
Wow... All this post needs is an installment from the deadly 'BUSHVIPER'...
(for those of you who have read my favorite thread off of EE BB).
Speaking of EE BB ... Does anyone's logon work on there ?
I love this thread... I'm thinking of upgrading... Keep the info coming... THANK YOU.
Nicholas Orros
Old September 28th, 2005, 06:21 PM
redrover
Guest
Posts: n/a
"I figured so much, my plan was to also add a 3-link so as to correct the front pinon and castor". Dave this statement is ok if you plan on running a stock fr drive shaft. Because the center link can be extended to keep pinion and output on TC in parallel. If you plan on a DC drive shaft you ideally want the pinion in line with driveshaft. In this case the centerlink is shortened to rotate pinion up, but the castor will suffer. I have a SG 3link on my truck. I experimented with rotating pinion in parallel with TC and a stock drive line. This didnt work because the drive shaft rubbed on the heavy duty cross member. So I rotated the diff up in line with shaft and use a double cardan shaft. I dont have redrilled swivels, and caster is way off. I said earlier that the SG 3link will not work with redrilled swivels. There is no room inside the SG tie rod box for the tie rod to be lowered with the redrill process on the swivels. You could fab your own 3link like on Johnathan Tisdales 9inch. That way you could run a HD bent tie rod that is tucked away. If you are going 3link dont waist money on caster corrected control arms. Anyway take a good look at a SG 3link and it will make sense. JP
Old September 28th, 2005, 06:35 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
I agree with JP. You can not have your balls redrilled and the 3 link... It just wont work. My 3 link is set up with a dc front shaft and i actually have it lowered about 3 degrees lower then the d shaft with no problem. THe steering is great and when I took it to the front end shop, they put it on the rack and he said the caster was not bad at all. I have the specs of what it was somewhere
Legend in My Own Mind.
Old September 29th, 2005, 10:55 AM
cbass's Avatar
cbass
Bradlee Duncan
'94 White and '95 Red D's
True, I didn't think about the re-drileld swivels with the 3-link because I haven't gone the route of a 3-link.....yet..ahem.
Randy, that's interesting the way that you have it set up there with no problems. I think you got lucky though (no offense and I wish mine were like that), but on our Red D90, it has just a 2" lift and you can feel a difference from the castor being off. It wanders when it's at higher speeds. I think most (maybe not all) lifts would suffer from this wandering to some extent or another.
As for the a-arm extension hitting the gas tank, generally all you have to do is lop off one of the corners about 1/2" and it'll clear the stock gas tank. This is only an issue with the d90's, not the disco's, maybe that's why Rovertym didn't mention it.
Old September 29th, 2005, 11:28 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Yeah, mine is great. with the 3 link. I think its a great system especially with its adjustability. I was able to adjust the pinion angle lower so it is almost stock but not low enough to start getting vibs from the DC drive shaft. Its all good even at 70mph.
Old September 29th, 2005, 11:32 AM
cbass's Avatar
cbass
Bradlee Duncan
very cool, you're making me want a 3-link now, hehe! I guess that will have to come after the diesel swap, lol.
Old September 30th, 2005, 12:01 PM
TwisteD90's Avatar
TwisteD90
Yousef Hamzeh
David, here is the set up you want to run. Fox 12" coil overs on all four corners, 3-link, anti-rock in the rear, b/c you know SW's are street queens and the only way you can make them happy is run a sway bar in the back b/c they like to take it in the back You will have a fully adjustable suspension and fox shocks are for life. The only bad part about running coil overs is you have to cut the front upper spring mounts and the rear upper spring mounts if you want to run them vertical, and yes 12" in the will fit on top of the axle. Give it a shot and you can thank me later. I guess Pendy can do the tube bending and welding assuming he know how to do this stuff
Old September 30th, 2005, 12:07 PM
sheki's Avatar
sheki
David Shechter
97' D90 SW 2.8L diesel
is that why you got rid of your truck... because it had all that shit onit?
Old September 30th, 2005, 12:33 PM
TwisteD90's Avatar
TwisteD90
Yousef Hamzeh
I gave up my truck for a personal reason to be honest!
Old September 30th, 2005, 12:48 PM
sheki's Avatar
sheki
David Shechter
yousef, sent you an email yesterday... your PM box was full
Old September 30th, 2005, 06:39 PM
redrover
Guest
Posts: n/a
140 mm Coilover all 4 corners, wishbone 3link . Took it into upper upper heldorado , Sick jP
ID:	3953   Click image for larger version
Old September 30th, 2005, 07:32 PM
TwisteD90's Avatar
TwisteD90
Yousef Hamzeh
I'm going to wall mart right to buy one.
Old September 30th, 2005, 07:50 PM
sheki's Avatar
sheki
David Shechter
but it's a jeep! Hey Yousef, are those D60's on it?
Old September 30th, 2005, 08:26 PM
TwisteD90's Avatar
TwisteD90
Yousef Hamzeh
I don't know but it's locked fr/rr. They have it in a buggy too.
Rovertym RR4-2 Springs RyanS For Sale - Parts 5 June 12th, 2014 11:43 PM
New Rovertym 5 Inch Springs FS SafariHP For Sale - Parts 3 November 27th, 2007 12:26 AM
FS: OldMan EMU & RoverTym parts RoverWrecks For Sale - Parts 14 June 12th, 2005 10:05 AM
Rovertym vs OME Springs Joe P Misc. Chit-Chat 10 December 10th, 2004 10:09 AM
3rd - Detroit Locker 4.10, 2" Rovertym Springs, Bodylift - Parting out Mudrover mudrover For Sale - Parts 6 July 18th, 2004 03:38 PM
