Rovers North Tail Lamp Guard Install - Defender Source
Old September 4th, 2008, 10:23 PM
Arnzo
Andrew Arnott
1997 Defender 90
Have any of you installed Rovers North's tail lamp guards? Drivers side looks pretty straight forward but the passenger side guard doesn't seem to sit flush. Specifically its the longer tab at on the bottom of the guard that doesn't touch the body of the truck. It seems to be about a quarter inch off the body. Also, the spot on the body where this tab should touch doesn't look like I can drill through and install a nut an bolt. Lastly, any tricks to drilling holes in the body?
Old September 4th, 2008, 10:29 PM
Either bend it yourself or let the nut and bolt tighten it down. For drilling, cover the are first with masking tape, you can make your mark on the tape, move it if necessary, and it will prevent the drill from possibly damaging the surrounding paint when you drill through.
And if you paid more than 30 bucks for those light guards, send them back and call RDS.
Old September 4th, 2008, 11:26 PM
LenB's Avatar
LenB
Len Bruffett
NAS '97 ST /SW-POE Config
I just built a nylon spacer and put it between the truck body and lamp guard. (you could use a stack of nylon washers if you don't have any nylon bar stock to fab a spacer). I used nylon so I would not muck up the paint on my truck.
Old September 5th, 2008, 12:00 AM
NashvilleRover's Avatar
NashvilleRover
Dendy Jarrett
2009 LR3- Well Built
Tips for drilling:
MEASURE THRICE. DRILL ONCE!!
D
Old September 5th, 2008, 07:49 AM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
Originally Posted by JSBriggs
Ive seen those 'guards' do more damage by catching on things. I think its better to run without them.
-Jeff
Agreed 1000%
Replace a broken lamp for a few bucks, or replace the entire rear panel for many bucks...
I never understood lamp guards either, but then again they bring us a lot of bodywork jobs so I guess I should like them.
Email:
Old September 5th, 2008, 08:54 AM
Grover's Avatar
Grover
What are they protecting anyway? I'd rather have a busted lamp lens than driled holes in the body work...my 2 cents...
Old September 5th, 2008, 09:06 AM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
I have them from the PO Don't bother. Those that wheel whith me have seen what happens when you back into a tree with them on. Drivers side is bent in to below the light and that bottom tab punched a hole through the body panel. So now its a royal pain to change the bulb. Granted this is on a 94.
Jimmy Buffett
Old September 5th, 2008, 09:48 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Same here - PO had installed them on my '95 as well. Getting the lense cover off to change a bulb is a PITA. You can't stand on them as much as they have a tempting location. They might look "cool" but I wouldn't mind if I didn't have them myself.
Old September 5th, 2008, 10:15 AM
GYM's Avatar
GYM
Gary
97 SW
Agree also. I took mine off. Put in small plugs to cover holes for now. Looks lame, but figure it's better than catching on something and really doing damage.
Old September 5th, 2008, 01:27 PM
Bozman's Avatar
Bozman
Greg
1991 200tdi D90
My LED's were a bit more than a few bucks . . . .
Old September 5th, 2008, 02:34 PM
ECR's Avatar
ECR
A replacement LED, or factory lens unit is still cheaper than fixing the 4 or so holes and dents that the lamp guards make when they get ripped off or dented in is my point.
Email:
Old September 5th, 2008, 08:44 PM
hutch's Avatar
hutch
Hutch
97 AA Yellow D90 ST
I just spent about 900 bucks fixing a bent rear quarter panel from the driver's side guards from the previous owner (saved the lights though ) That being said it definitely looks better with them on!
Old September 5th, 2008, 10:54 PM
Arnzo
Andrew Arnott
1997 Defender 90
Wow, thanks guys. I think I paid $25 or so but I think I'll hold off on putting them on...perhaps never put them on. Thanks for the advice.
Old September 6th, 2008, 07:17 AM
They'd be great for a trailer
lamp
Rovers North Custom Stainless D-90 roofrack for sale bconab For Sale - Parts 5 May 11th, 2006 10:53 AM
Tail light lamp guard sheki For Sale - Parts 4 January 12th, 2006 08:50 AM
Rovers North 1.5 inch lift kit w/shocks Seriesman For Sale - Parts 1 August 26th, 2005 11:45 PM
Gutter Kit w/ Rovers North (Badger) Top mgrgpg Defender Technical Discussions 4 March 28th, 2005 12:56 AM
Mantec or Rovers North winch bumpers c2sox Wanted 6 June 9th, 2004 11:13 AM
