Rovers North HID Xenon kit? - Page 3 - Defender Source
Old October 14th, 2010, 03:04 PM
Chaucer
Will
93 110 | 97 90
Another option to consider, which I am in the process of doing:
From Daniel Stern Lighting:
Cibie H4 headlamps—7” round - H4 high/low beam, convex (domed) lens: $74.95/ea.
Regulatory compliance: ECE (European E-Code); SAE M
- (much better beam pattern than the Hellas mentioned earlier)
H4 70/65W Osram Plus 50: $22/ea
From DAP:
H4 Upgrade Harness: $100
End Price: ~$300.00
I've started with the H4 wiring harness. Once my headlights go out, the I'll drop the $200 for the lenses & lamps and be done.
Old October 14th, 2010, 04:08 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
Originally Posted by Chaucer View Post
From DAP:
Wow!
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old October 14th, 2010, 05:36 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
The JW speaker lights are made in the US. No need to buy from Britain. Looks like they have dropped significantly in price as well. http://www.whelendirect.com/JW-Speak...Beam_Headlamps
Originally Posted by Red90
Option 3: JWspeaker LEDs, $2000 (price from Mobilcenter, anyone find a cheaper price?)
Old October 14th, 2010, 07:37 PM
That is much better. So.
Option 1: H4 upgrades. Hella or IPF ecode housings, quality H4 bulbs, relays and larger wiring. $130
Option 2: Truck-Lite LEDs, $600 (have really dropped in price!!)
Option 3: JWspeaker LEDs, $960
Option 3: Osram bi-xenon, $700
Option 4: Detroitspeed fully sealed housings with 9007 bulbs, wiring and relays. $250
I personally have Hellas and the light is very good, but they leak when I do this: http://www.youtube.com/user/1104kdd#p/u/3/1D8POUOpAc4 I think I'm going to try the Detroitspeed ones. The 9007 bulbs last 10 times as long as an H4 and are designed to be sealed.
------ Follow up post added October 14th, 2010 05:39 PM ------
From DAP:
What does that include? You need relays, you need bigger wires. Total cost should be around $20 to $30.
------ Follow up post added October 14th, 2010 05:55 PM ------
Really, why do you think this?
Old October 14th, 2010, 10:23 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Thanks for listing the options. I have Hella Vision Plus headlights with replaceable HB2 type bulbs. What do you guys think of them? They are barely ok. Still not sure what to upgrade to but the list certainly helps.
Check out these work lights. I might swap out my rear Hella Work light for one of these: http://www.whelendirect.com/JW-Speak...KLAMP_New_item
Old October 15th, 2010, 10:38 AM
ajh
Andrew J. Hutton
1993 Defender 110 200TDI
Going with 55/100W bulbs and reversing the dip switch so you get both on the locked setting will make the biggest difference to visibility. The stock high-lamp switch turns off the dip in the locked (forward) position so you lose the light you need to see animals waiting in the ditches about to run out in front of you. Swapping the two (the intermittent and locked position wires) fix this. The heat shouldn't be an issue unless you're doing night creek crossings and turning them down to low in advance would help with that.
Old October 15th, 2010, 12:02 PM
Chaucer
Will
93 110 | 97 90
From DAP:
Comes with everything needed, relays, bigger wires, the stock wiring/switch plugs right in, except it is the power switch for the relay, which of course in turn powers the headlights. I was a moment of stupidy and desperation. I wanted to "save time" so I sprung for it. But in the end it wasn't as plug and play as I hoped, and ended up modifying it a little anyway.
Old October 15th, 2010, 12:22 PM
ajh
Andrew J. Hutton
If you can wire it's not difficult and you can grab a 4-relay box at the same time and some horns and do it all at once.
Old October 15th, 2010, 12:27 PM
Chaucer
Will
93 110 | 97 90
Right, and I found out the wiring was 12 gauge throughout. And the relays are the nice dual 87 terminal type.
Old October 16th, 2010, 11:25 AM
Have you upgraded the wiring and put in relays? Did you get the ecode versions? The stock wiring is horrid and drains a lot of power. With stock lights, I measured 18% voltage loss on high beam. Went to 2% after modifying the wiring. They are as bright as any modern car with quality stock wattage bulbs and better with high wattage bulbs.
Old October 16th, 2010, 04:41 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
I'm going to order the ARB H4 upgrade harness. I ordered the Hella H4's but I think I will return them. I think I'll either get IPF's with upgraded bulbs or LED headlights.
Old October 16th, 2010, 11:11 PM
IPFs will be the same as the Hellas. They are a very good light.
kit
FS True Xenon HID Kit for Defender Stmpede For Sale - Parts 13 November 10th, 2008 07:29 PM
Rovers North Custom Stainless D-90 roofrack for sale bconab For Sale - Parts 5 May 11th, 2006 10:53 AM
Rovers North 1.5 inch lift kit w/shocks Seriesman For Sale - Parts 1 August 26th, 2005 11:45 PM
Gutter Kit w/ Rovers North (Badger) Top mgrgpg Defender Technical Discussions 4 March 28th, 2005 12:56 AM
Mantec or Rovers North winch bumpers c2sox Wanted 6 June 9th, 2004 11:13 AM
