rovergauge iphone/ipad compatable? - Defender Source
Old May 16th, 2015, 12:33 AM
EnduroPro's Avatar
EnduroPro
Stephen LeBlanc
1994 Defender 90
Wondering if rovergauge advanced to iphone app yet. I google'd the heck out of it and found nothing. Seems logical with this (attached) piece of hardware.
Anything out there on this, or should I prep to use my laptop?
Old May 16th, 2015, 06:36 AM
Nope. Been thinking about obd2 stuff for Ios and my DD.
Old May 16th, 2015, 01:26 PM
cellulararrest's Avatar
cellulararrest
Chris Snyder
1994 D90 #614 | '07 L322 SC
Nope. I've toyed with the idea of building an interface for android, but it'll probably never happen.
Old May 16th, 2015, 07:07 PM
carlosz's Avatar
carlosz
Carlos
Been toying with the idea of using obd 2 connector, just don't know if Communications protocols will allow me to use an obd2 scanner, vrs rover gauge and or air ride software.
the truck ran like a "raped ape"
A fussy warm weather creature...
Old May 17th, 2015, 06:23 PM
Originally Posted by EnduroPro View Post
Wondering if rovergauge advanced to iphone app yet. I google'd the heck out of it and found nothing. Seems logical with this (attached) piece of hardware. Anything out there on this, or should I prep to use my laptop?
That's a VGA connector. For a monitor. Useless for rover gauge.
Old May 19th, 2015, 10:14 PM
carlosz's Avatar
carlosz
Carlos
Spoke with someone the other day and asked your question and concern...the response, android is Linux based so technically using the proper ports an android pad should work....I have yet to try...
Old May 19th, 2015, 10:25 PM
You can be so mean sometimes.
Old May 19th, 2015, 10:29 PM
EnduroPro's Avatar
EnduroPro
Stephen LeBlanc
1994 Defender 90
Not useless. VGA is the male/female connection that the architect provides as an option to connect. It's simply a plug that you can code however you want. Google it.
Old May 20th, 2015, 06:44 AM
Let me know when you have it working....
Old May 20th, 2015, 10:03 AM
cellulararrest
Chris Snyder
VGA != RS-232. Sorry. You could use something like this though: http://redpark.com/lightning-serial-cable-l2-db9v/. But, not being familiar with the iOS APIs I have no idea if you can even succesfully make use of that thing without a jailbreak.
Unfortunately it's not that simple at all. C code needs to be ported to the android NDK and an interface built. It would just be a lot less work than getting it going on iOS, but it's still not all that easy.
Old May 20th, 2015, 10:15 AM
jafir's Avatar
jafir
Jafir Elkurd
VGA = analog signals
RS232 = digital signals.
Code isn't going to change that.
Old May 20th, 2015, 10:55 AM
You can't. The USB on an IOS device can't be used as a host. You can't have two way communication. It is all locked down.
You can use Bluetooth, but that requires a special BT stack and fee payments to Apple.
ipad, rovergauge
libcomm14cux/RoverGauge cgalpin Smaller Projects 50 November 17th, 2014 05:29 PM
ODB Dashboard Tool With the iPad/iPhone Dogpilot Smaller Projects 6 February 1st, 2014 04:47 PM
iPhone and iPad mounts bossman429 Misc. Chit-Chat 43 October 4th, 2013 12:12 AM
Rover iphone/ipad Wallpapers genie90 Misc. Chit-Chat 25 July 9th, 2013 04:00 PM
95 nas or compatable column surround orionpco Wanted 1 January 19th, 2011 08:14 PM
