Rovergauge cable help - Defender Source
Old April 22nd, 2013, 07:10 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
The shop sent me the 3.3V cable in lieu of the 5V USB-TO-SERIAL cable. Can I still use that or do I need to return it? Can I possibly use a different value resistor in order to compensate?
If you know, please share. I am not savvy on this end of computer stuff...
Old April 22nd, 2013, 10:10 PM
I don't know but I'd get the proper cable if you can. It's complex enough trying to troubleshoot without have a cable that's non-standard!
Old April 23rd, 2013, 12:01 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Looks like the resistor is to protect the CPU signal output from damaging the computer on the receive line. The 5v output is necessary to trigger the CPU to receive input and the 3.3 v just isn't powerful enough. That's what I'm thinking. I'll test it tomorrow, see what's up... Thinking ill need 5v...
Old April 23rd, 2013, 08:09 AM
MAX711's Avatar
MAX711
Andrew Dance
1994 D-90 ST
The 14CUX has a non standard serial comunication setup, the Rx line is at system voltage (12v). The 390 ohm resistor drops the voltage down to protect the FTDI chip in the serial/usb converter. In my rush to try it, I accidentally ran without the resistor and everything worked ok. I have since added the resistor to avoid any future problems. This is the cable is used, works great: http://www.amazon.com/USB-Header-Lik...ef=pd_sxp_f_pt
Good luck
Old April 23rd, 2013, 08:14 AM
Someone reported using a cheaper cable as well - check the hardware wiki page
Originally Posted by pendy
I'm here for the D's
Old April 23rd, 2013, 10:14 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I used the resistor, but I get an error: "Error connecting to 14CUX. Could not open serial device: \\.\"
This may be that I need a stronger voltage to the ECU (than the 3.3V supplies), or it may be that I am doing something else wrong... (I did order my 5V version as well--have it next week)
Old April 23rd, 2013, 10:39 AM
MAX711's Avatar
MAX711
Andrew Dance
1994 D-90 ST
1) Double check that you programed the FTDI chip to invert the RX line. Mine didn't take the first time for some reason.
2) Be sure it's wired exactly like the diagram with the TX and RX swapped. Another mistake I made.
After that, it's probably too low a voltage or your particular cable can't match the weird baud rate from the 14CUX automatically?
Old April 23rd, 2013, 01:57 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I double checked the wiring and inverted the RX line. Still same "Error connecting to 14CUX. Could not open serial device: \\.\" I get this error whether or not the cable is even plugged into the computer, so I am unsure if it is a cable or maybe my laptop. The new cable is on order, but I am not 100% it is just the cable--could be my POS laptop...
Old April 23rd, 2013, 02:06 PM
Stupid question, but have you selected the right port?
Old April 23rd, 2013, 02:25 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I'd have to say probably not. Where do I select the port? I don't see that option in rovergauge. Sorry to be so stupid when it comes to this--I am not too savvy on this side of things. I am more of an under-the-hood sort of guy...
Old April 23rd, 2013, 02:29 PM
I don't have it here to look at but check the file or options menu at the top left of the screen.
Old April 23rd, 2013, 03:00 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Got it! Thanks. I believe it is working now--at least it is connecting (using the 3.3v version). MUCH APPRECIATED!
rovergauge
Detach Speedometer Cable Matt Klapmust Defender Technical Discussions 2 October 2nd, 2013 01:43 PM
speedo cable scoloco Defender Technical Discussions 7 November 3rd, 2005 07:54 AM
Kickdown cable on ZF, DOH! RedRhinoProducts Defender Technical Discussions 0 November 13th, 2004 10:32 AM
Sub woofer cable? wicks Defender Technical Discussions 17 May 18th, 2004 09:51 PM
Installing new kickdown cable...anyone? P1CR Defender Technical Discussions 4 December 19th, 2003 01:15 PM
