Rovergasm!!!! - Defender Source
Old March 5th, 2007, 10:10 PM
ScottYates's Avatar
ScottYates
Scott Yates
94 D90 #639, Yellow
Talking Rovergasm!!!!
It's fixed!! Three months and nearly $3k and it's finally fixed. The last problem, the one that stopped the engine from passing 3200 rpm.......was two large holes in the air tube between the MAF senser and the plenum.
A special thanks to Pendy for numerous phone calls and the time he spent helping me. It was Pendy who suggested I check the air tube as we were running out of options.
I patched it up the holes temporarily with electrical tape to see if that fixed it. It runs GREAT now except that I found a blown exhaust gasket lol.
Thanks to everyone that helped and weighed in with suggestions.
Some people are like a slinky... not really good for anything, but you still can't help but smile
when you shove them down
the stairs.
Old March 5th, 2007, 10:13 PM
themaxx's Avatar
themaxx
Ade
94 ST
How the hell did you end up with two holes in the air tube?
Old March 5th, 2007, 10:36 PM
brn24whl's Avatar
brn24whl
Eric
1994 RRC SWB
We get calls often from guys that say they dry rot and start falling apart. They look tough but I guess engine compartment heat dries them out.
Eric
Eric Riston
1-800-533-2210 ext 231
Direct Line 518-539-2231
Old March 5th, 2007, 10:43 PM
ScottYates's Avatar
ScottYates
Scott Yates
94 D90 #639, Yellow
It would appear that at sometime the retention bracket was shoved down allowing the tube to touch the steering shaft knuckle. It wore 2 big wholes in it. It looked perfect until it was all the way out of the truck.
the stairs.
Old March 5th, 2007, 11:15 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Was this the hard fiberglass-type air tube? or the more flexible corrugated type?
-Hans
My oil line fix
My 100k stopped odometer fix
Old March 6th, 2007, 02:05 AM
ScottYates's Avatar
ScottYates
Scott Yates
94 D90 #639, Yellow
The corrugated type tube.
the stairs.
Old March 6th, 2007, 10:25 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I am very glad you got it fixed. Good work Pendy--I would not have thought of that. I might use this technique in the future to upgrade parts on my D90--I will poke a hole in my air intake tube, buy a 3-link suspension and long travel shocks to fix it, put in a roll cage, tell my wife it still is not running, then put some duct tape on the hole. Great suggestion--if she gets pissed, I will tell her it was your idea!
Old March 6th, 2007, 11:41 AM
ScottYates's Avatar
ScottYates
Scott Yates
94 D90 #639, Yellow
I hope for your sake she doesn't know the address of this board. That could get ugly.
the stairs.
Old March 6th, 2007, 11:55 AM
Doug's Avatar
Doug
Doug Walker
TVR5L-powered NAS D-110
Congrats, Scott! What a saga....
Doug W.
Old March 6th, 2007, 12:54 PM
pendy's Avatar
pendy
jim pendleton
89'd90
I was putting together a diesel conversion package for Scott $. But when his wife threatened divorce I went ahead and helped him fiz it!
JP
legend in my own mind
Old March 7th, 2007, 11:48 AM
d901560's Avatar
d901560
Brian B
94 ST
That's good to know. I have the hard fiberglass type hose and for a while it was cracked and caused the check engine light to come on. I didn't notice any performance problems though. Some duct tape was a short term fix that keep the CEL turned off until I replaced it. I remember that hose was really expensive to replace.
Old March 8th, 2007, 10:44 PM
Paul Davis's Avatar
Paul Davis
Paul Davis
97 ST
I convienently have the same problem only the cause of mine is the supercharger displaces the hose just enough to rub on that knuckle.
Did you replace it with the hard or corrugated type hose?
Old March 13th, 2007, 12:47 AM
ScottYates's Avatar
ScottYates
Scott Yates
94 D90 #639, Yellow
I replaced mine with the corrugated style on Penndy's recommendation. I found a really good deal for it at www.wholesalelandparts.com
Rover 1994 Air Mass Meter Hose Price: $80.95 Qty: 1 Part #: B3100-142215
All of the other places I looked wanted ~$220 for the same part. This is a Land Rover OEM part. I have no idea why they were so much cheaper. Hope this helps.
the stairs.
Old March 13th, 2007, 06:45 PM
Paul Davis's Avatar
Paul Davis
Paul Davis
97 ST
Thanks. The best price I can find is $262.00. That will help a lot.
Old March 13th, 2007, 08:55 PM
ScottYates's Avatar
ScottYates
Scott Yates
94 D90 #639, Yellow
Don't worry Paul. The part I recieved was in a plastic bag with a LR sticker. It was identical to the one I pulled out (other than no gapping holes). Nice tight seals. Works great.
the stairs.
gas
