Roverdrive - Defender Source
Old June 6th, 2012, 09:31 PM
solarguy's Avatar
solarguy
Abraham Bell
1985 Defender 110 Tithonus
Roverdrive
Ok I would like to keep my 1.6 transfercase for the off road control but would like to have a higher ratio on the highway. Does anybody have any thoughts about a roverdrive? I plan on putting a 200tdi in the truck and would like to run tires in the 32-33" range. Please people give me some guidance?!?!
Old June 6th, 2012, 10:27 PM
1.6 is only the high range. Low range are all the same.
Old June 7th, 2012, 12:04 AM
El Solis's Avatar
El Solis
Chris Solis
Camel Trophy 110 sorta :)
You do not want a 1.6 behind a 200 Tdi. I did that for a very short while, engine over revs the T case First second and third gear maxed out very quickly. If you are going 200Tdi then at least a 1.4 box is in your future.
Old June 7th, 2012, 03:57 AM
nothing good about a 1.6 unless you plan on 35+ inch rubber. Get the correct 1.4 and you will be much happier.Sent you several texts-got a cur pup Tn last week.
Old June 7th, 2012, 05:42 AM
CDNRover's Avatar
CDNRover
Jeff Labbé
110 Ex-Mod FFR 200tdi
I ran a 1.6 for more then a year, it is a bit too short but, it pulls like a train! Top speed, mated to a 200tdi, will be around 55-60 on 32-33 inches tire. It all depends on the use, first gear feels like low range. Usually I skipped the first gear except for hill start up while pulling a trailer. But if you don't expect to drive at highway speed for long journey, it ain't that bad. Most people want the look of a defender with average car performance, if you're after that install a 1,4 but, if off-road is the goal, try it! It is purposeful.
Sent from my iPhone using Forum Runner
Old June 7th, 2012, 01:37 PM
? low range gearing for off road is the same in all lt230's ?
Old June 12th, 2012, 05:18 PM
solarguy's Avatar
solarguy
Abraham Bell
Okay so it sounds like I need a 1.4 . Does any body know anything about roverdrives? Good, bad, indifferent? Can they be used in all gears or just 4th and 5th? And if not then why?
Old June 12th, 2012, 05:42 PM
Yes. The only way to lower the low range gearing is change the diff ratios. Then you need to change the hi range gearing in the transfer box to keep cruising bearable.
Of course tire size also can cause changes in the what I call effective crawl ratio.
Old June 12th, 2012, 05:45 PM
I was wondering about this myself. So you're saying that a 1.003, 1.222, 1.41, or 1.6 all have the same/similar low range gears and it's only the high range ratio that's affected?
Old June 12th, 2012, 05:46 PM
You can get lower low range gears out of Australia as well.
Old June 13th, 2012, 05:17 PM
solarguy's Avatar
solarguy
Abraham Bell
So does anybody have a roverdrive?
Old June 13th, 2012, 06:24 PM
Josh should be able to find the post... A board member installed one and said great things...
Old June 13th, 2012, 08:01 PM
oldgreentrucks's Avatar
oldgreentrucks
Jim Pace
Roverdrive
I installed a Roverdrive on a '94 NAS D90 around 2004. Stock tires but 4.1 ARB diffs. Use the OD mainly for cruising to keep the rpm reasonable. Works well in 3rd 4th 5th. No harsh treatment especially in 3rd!
Very happy.
Had a spring clip failure once when someone else was driving it that locked the shifter between gears. Good tech support for Roverdrive. Removed and repaired quickly.
However, it does not shift as positively as the OD in my Series III.
My two cents...
Old June 13th, 2012, 08:06 PM
solarguy's Avatar
solarguy
Abraham Bell
What do you mean" shift as positively "?
Old June 13th, 2012, 08:16 PM
mgreenspan's Avatar
mgreenspan
Matthew Greenspan
Land Rovers
Low range is the same in all LT230s unless somebody has changed the ratio out for something else. How are these discussions always creeping up?
You little rebel, I like you.
Old June 13th, 2012, 08:22 PM
For me personally I've got a 1.222 tcase with what I *think* are 4.75 diff gearing...I'm pushing like 3500 rpms at 70mph on the highway. Was talking to Galpin about swapping out tcase for a 1.003, but was afraid that would detract from the offroad performance. Honestly, I didn't realize the low-range gearing is not affected...and neither did Charles I think. But that's good news, may be the solution to driving down my rpms.
Old June 13th, 2012, 08:31 PM
mgreenspan's Avatar
mgreenspan
Matthew Greenspan
Land Rovers
What engine do you have? Also, why'd you put in 4.75 gearing?
Old June 13th, 2012, 08:37 PM
3.9 motor. Gears came in the truck...to be honest I haven't done the calcs of tire rotation to drive shaft rotation to figure it out exactly, so just assuming 4.75 since my rpms are through the roof at highway speed. But PO had 35s on it since it was a backcountry wheeling truck in AZ so I'm guessing the lower gearing was for crawling/etc. However, I was/am very happy with it's trail performance so don't want to impede on that since it's essentially the trail rig. Would just be nice for getting to the trails (or putting the wife/kid in it) to get those highway rpms down. The other solution...buy a trailer!
Old June 13th, 2012, 08:48 PM
mgreenspan's Avatar
mgreenspan
Matthew Greenspan
Land Rovers
I have stock diffs, 7.50 tires, and a 1.003. If you do not have a super torque-y engine you will be over geared with the equivalent setup. I can only use 5th gear above 55mph and that's just above lumbering. Better to shift to 5th once I've found a speed to maintain above 60-65mph.
You're going to a lot of effort to correct the problem that is caused by the high gear ratio at the diff which was added for crawling and moving the bigger tires. I'd think the best solution is to just drive 55-60mph instead of 70mph or get a trailer like you said. You could get a 1.003, but why? The truck was built in one direction and you're trying to work it back in another. Just thoughts on that. A 1.003 might make it more highway friendly, but do you need to take a trail truck 70mph?
Old June 13th, 2012, 08:55 PM
I've sort of come to the same conclusion (leave it as-is), but every time I try to keep up with Jeff Huff on the highway I realize that driving 60-65 reeaaallly sucks. So toying with the idea of a 1.003 tcase - if it doesn't affect offroad performance - did/does seem like an option. Or an overdrive....which is what piqued my interest in this thread.
I guess bottom line is driving 65 in the Series is ok....but driving 60-65 in a 90 seems like a shame when you're actually trying to get somewhere (most wheeling around DC requires 3+ hour drive, not so when I'm in NY though).
Roverdrive LT230 T-Case Oil Cooler Cover Alberto_SD For Sale - Parts 5 June 24th, 2011 11:09 PM
1993 nas defender with 2.8 turbo. Tallergypsy For Sale - Vehicles 3 January 1st, 2011 09:47 PM
ROVERDRIVES FOR NAS DEFENDER 90s Tallergypsy The Vendors Loft 17 October 9th, 2010 11:22 PM
ROVERDRIVES FOR NAS DEFENDER 90s Tallergypsy The Vendors Loft 0 June 27th, 2010 09:35 PM
Roverdrive in Tdi? JackW Defender Technical Discussions 5 March 22nd, 2006 07:55 AM
