Round LEDs - Defender Source
Old May 21st, 2013, 10:00 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Round LEDs
What is current state of the art LED?
I'm thinking about some auxillary lights for the RR Hunter but these square LEDs just don't look *right* on a RR Classic.
I'm keeping my stock 7" headlights(actually IPF euros with relays), I just hate the look of the LED headlights.
I like the Rigid Industries, but in my brief search I only found square housings...
Any good looking round lights out there?
Old May 21st, 2013, 10:46 AM
slorocco
Dan Prasada-Rao
1963, 109 Station Wagon
Jeff, have you seen the trucklite LED headlights? They seem pretty nice but are very pricey.
Old May 21st, 2013, 10:52 AM
BEIS's Avatar
BEIS
RYAN BEIS
D110 Soft Top with full rollcage
I have Trucklite LED headlights on my Hummer H1, and to be honest, I'm a little disappointed. They don't put out half as much light as I want. However, the newer verson, that just came out a couple months ago might be better.
-Ryan
Old May 21st, 2013, 11:38 AM
maleger
Marc-Andre Leger
I have the old trucklite model on mine, you can find them on eBay. I love it !
ID:	72768   Click image for larger version
Old May 21st, 2013, 11:39 AM
maleger
Marc-Andre Leger
The old style RDX led lights with RDX protectors are also visible. Also available on eBay BTW.
Old May 21st, 2013, 11:57 AM
boswalt's Avatar
boswalt
Brian Oswalt
1988 exmod 110
Are the military lights dual voltage? Can you run them on a 12v system and will they run as bright?
Old May 21st, 2013, 11:59 AM
slorocco
Dan Prasada-Rao
I believe the Trucklite brand sell two different part numbers for the 24v and the 12v
Old May 21st, 2013, 12:28 PM
BEIS's Avatar
BEIS
RYAN BEIS
Military lights (especially Trucklites) are NOT dual voltage. You need to specify 12V if you don't have a military setup. Lots of guys have pulled the trigger on less expensive Trucklites to find out they bought the 24Vs...then they're out a couple hundred $.
Be careful what you buy!
-Ryan
Old May 21st, 2013, 12:30 PM
The OP is NOT asking about headlights....
He is asking about auxiliary lights.....
Old May 21st, 2013, 12:36 PM
Haven't checked the rallylights website in a while.
My sense is that as work lights LEDs are good but traditional halogen etc type lights are best for fog/driving etc
Old May 21st, 2013, 01:21 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Yep, I just don't care for those headlight LEDs.
I did see some Trucklite auxillaries; in the 4.5" size I think.
Old May 21st, 2013, 01:23 PM
Macker's Avatar
Macker
Mack Crouch
1988 110 LS 5.3
http://www.visionxusa.com/LED-Optimu...254/index.html
You can check out Vision X, they make a few different round led aux lights.
Old May 21st, 2013, 01:24 PM
Howski's Avatar
Howski
Kevin
2002 Land Rover Discovery II
I have no experience with these just saw them advertised awhile back
http://www.arbusa.com/Uploads/PDF/ne..._LED_light.pdf
Old May 21st, 2013, 01:33 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
My IPFs are hardwired with relays.
I'll check some of those links out.
Wow...those ARBs are expensive! But, I don't like all the red...
Old June 6th, 2013, 12:21 PM
RicardoCarroll
RicardoCarroll
Were you able to get them? You can search for lights in ebay or amazon. I think it is the best place to get lights in cheaper rates. Try your luck
Old June 6th, 2013, 02:54 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Haven't gotten anything yet.
Ideally, I'd like one that looks like a Hella 1000 but is LED.
I didn't care for the looks of those square housing/round light combos.
They need to compliment the RRC's aesthetics.
Rent my
Old June 6th, 2013, 03:30 PM
Macker's Avatar
Macker
Mack Crouch
1988 110 LS 5.3
http://www.amazon.com/gp/aw/d/B00A0P3RNC
Old June 7th, 2013, 11:44 AM
RicardoCarroll
RicardoCarroll
Originally Posted by RicardoCarroll View Post
Were you able to get them? You can search for led lights in ebay or amazon. I think it is the best place to get lights in cheaper rates. Try your luck
Ok thanks for reply
Series Round Wiring Block 61rover Wanted 3 October 30th, 2012 01:44 PM
land rover defender LED's for dash gauges James5810 For Sale - Parts 9 August 31st, 2012 06:45 AM
LED's installs - Lets see 'em JimC Defender Technical Discussions 73 August 30th, 2012 12:05 AM
Safari Dust LEDs CDeWan Defender Technical Discussions 1 May 4th, 2011 09:36 AM
IPF 900XS round Lights RoverChic For Sale - Parts 1 February 1st, 2006 01:26 PM
