Rough Idle when engine is cold - Defender Source
Old May 10th, 2011, 02:36 PM
Jon_Winningham's Avatar
Jon_Winningham
Sterling M Archer
1995 AA Yellow NAS D90 #2986
Rough idle when engine is cold, but after driving for 5 min. is smoothes out.
Would a bad diode in the alternator effect the idle?
I had the alternator tested and was told it was find. But it idles rough when cold, and intermittently the amp-meter needle wavers.
1995 NAS Defender 90 AA Yellow #2986: Current
2009 Range Rover Supercharged Black/Black: Current
1993 NAS Defender 110 #375/500: Sold
1995 NAS Defender 90 Soft Top Beluga Black #2556: Sold
1991 Range Rover Hunter Green: Sold
1997 NAS Defender 90 Station Wagon Portofino Red #128: Sold
1993 NAS Defender 110 Beluga Black #215/500: sold
Old May 10th, 2011, 03:01 PM
Naplm00
Matthew
the amp needle is wavering because the engine is sputtering...the drop in revs will cause a drop in current produced by the alt.
My 200tdi does the same thing, its very rough to start when cold but after about 2-3 min of white smoke when driving it evens out and idles fine with no smoke
Old May 10th, 2011, 05:07 PM
Jon_Winningham
Sterling M Archer
the app-meter will waver occasionally hot or cold, thought that it may do this because of an intermittent diode issue that is hard to detect by testing the alternator
engine, idle
Rough Idle @ Cold Start Grover Defender Technical Discussions 7 May 23rd, 2008 08:24 PM
Cold engine idle surges Bozman Defender Technical Discussions 4 May 22nd, 2007 09:21 AM
Fault Code 48/fast engine idle speed arbik Defender Technical Discussions 9 June 2nd, 2006 07:02 AM
Check engine light / Rough Road mhansen Defender Technical Discussions 16 June 9th, 2004 01:14 PM
