Rough Idle @ Cold Start - Defender Source
Old May 5th, 2008, 12:00 PM
Grover's Avatar
Grover
Question Rough Idle @ Cold Start
O.K.- At a cold start, the engine idles rough for about 5-10 seconds then idles smooth @ 750rpm. If the engine is warm when started, there is no problem. So far I have done the following:
- cleaned stepper motor
- cleaned stepper motor housing
- checked the dist. cap for cracks - no cracks
- checked for vacuum leaks - no leaks as far as I can tell
Stock 3.9L engine with 70K on the clock.
Any ideas?
Cheers...
Old May 5th, 2008, 02:23 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
silly question.
When you start it, do you just turn the key straight to "Start"? Or do you put it to "On" for a few seconds first?
-Hans
My oil line fix
My 100k stopped odometer fix
Old May 5th, 2008, 03:42 PM
Grover's Avatar
Grover
I go straight to start...
Old May 5th, 2008, 03:51 PM
Hans's Avatar
Hans
Hans Haase
Try turning the key to on, wait about 5 seconds, and then start it. It's possible your fuel pressure is bleeding off if it's shut down for too long. The pump goes through a priming cycle every time you turn it on, so leaving it in the "ON position for a bit will re-pressurize the system for you.
-Hans
My oil line fix
Old May 19th, 2008, 06:28 PM
Grover's Avatar
Grover
Thumbs up
Hans,
You nailed it! I wait 'bout 5 seconds after I rotate the ignition to "ON" and then I start it, problem solved...
Cheers...
Old May 23rd, 2008, 05:07 PM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
Originally Posted by Grover
Hans,
Cheers...
So you have a fuel issue. It might get worst in the future..... Monitor it / get to the root of it when you have some time.
MonLand
1995 D90 NAS
1996 Discovery NAS
Old May 23rd, 2008, 08:06 PM
Grover's Avatar
Grover
Question
What fuel issue?
Old May 23rd, 2008, 08:24 PM
theres a check valve thats supposed to stop the fuel pressure from bleeding off like that. Could be your fuel pump is starting to act up. Could last for years.
idle, start
Used to start rough, now not at all! Help. RickM Defender Technical Discussions 13 December 17th, 2009 04:00 PM
Cold start problem flippedrover Defender Technical Discussions 3 February 13th, 2008 06:52 PM
Rough idle, stumbling, dying.... revtor Defender Technical Discussions 9 January 10th, 2008 04:28 PM
Rough Idle After New Oil Lines floyd650 Defender Technical Discussions 4 December 26th, 2007 04:32 PM
The latest show-stopper: dies at idle, only runs above 2K rpm jaherring Defender Technical Discussions 34 December 23rd, 2004 07:05 PM
