Rough idle, almost missing, cold weather seems worse - Defender Source
Old January 6th, 2014, 08:45 PM
tebby's Avatar
tebby
Justin Tebbenkamp
95 D-90 ST
Daily driver. Truck has always ran rich. Recently replaced fuel pump, filter, new battery. Other day, before replacing battery, very hard start. Let idle for almost 2 hours....afterwards ran very smooth. With this cold weather, idle has been awful....almost sounds like it's missing. Cranks right up with new battery but very rough with obvious loss of power. Does this sound like a vacuum issue? O2 issue? Cap/motor/wires/plugs approximately 5 years old. Does the 95 have a MAF or is that only the 97? Any suggestions much appreciated!
Old January 6th, 2014, 10:34 PM
thewap's Avatar
thewap
Marc
'95 D90 SW#106
Would be good to start with new plugs, wires, cap, rotor , air filter, after 5 years. '95 has MAF, clean the MAF & connect. Are you throwing any codes?. Also check and clean coil wires, stepper motor...
Old January 6th, 2014, 10:58 PM
I would start with cap/rotor/wires (and plugs). Check for vacuum leaks. Hole in the intake hose. Clean PCV etc. the easy cheap stuff to get a baseline. Any check engine lights? Could be the coolant temp sensor. That would explain the rich running and bad idle. What do you have in the way of spare you could throw at it? MAF you could eliminate by trying to start it with the MAF unplugged.
Rough Idle when engine is cold Jon_Winningham Defender Technical Discussions 2 May 10th, 2011 05:07 PM
Rough Idle @ Cold Start Grover Defender Technical Discussions 7 May 23rd, 2008 08:24 PM
Cold Weather Starter Problems boshea Defender Technical Discussions 9 October 25th, 2005 04:35 PM
1st really cold weather questions mspell Defender Technical Discussions 6 December 20th, 2004 08:40 PM
? for you cold weather people javelinadave Defender Technical Discussions 8 November 24th, 2004 12:34 PM
