Rough acceleration when Hot... won't restart if I stall her - Defender Source
Old May 3rd, 2012, 07:50 PM
jijalicious
Jiman Khosravan
'94 D90
Unhappy Rough acceleration when Hot... won't restart if I stall her
Evening all,
I've done a bit of research but most of the threads a bit old so wanted to see if new ideas where "developed" since then
94 D90 3.9L V8 R380 w/ Mallory Dizzy
When engine is cold, no problems.. starts and runs smooth as a baby's butt... (with chicken pox that is)
As I get stock in traffic.. being from DC that's likely to happen at 3am as it is at 5pm...
As the engine gets hotter, the rougher the start off becomes. As in put her in 1st gear and I have to rev it up more to cause it from stalling since she sputters and the truck just jerks hard until revs go up. But once rolling, no issues. If i'm stuck too long in traffic, and I stall her, then she won't turn on until I wait a good 10-15 minutes.
When this symptom starts, if I just rev the engine, absolutely no problems.. it's only when I try to drive off... so basically when the load is on her to move.
Since I'm able to gas it in neutral and it shows no signs of dying, that is throwing me off... So what am I missing?
The engine never gets hot enough to show red on the temp gauge... since my electric fan kicks in correctly at the right time
Some posts have found:
http://www.defendersource.com/forum/...ad.php?t=14031
O2 sensor ready to fail
Do I just replace them?
Failing ignition module.. doesn't apply since I have a mallory distributor
http://www.defendersource.com/forum/...ad.php?t=24975
Bad spark plugs?
Replaced 2 years ago, how often to replace these?
Bad mallory resistor? Bad cap? Bad coil?
Replaced all of them last fall when she wouldn't start after terrential downpour (different post)
http://www.defendersource.com/forum/...ad.php?t=23890
Rebuild your Distributor and fresh plugs with the correct gap?
Distributor cap is new, but Plugs are exactly 2 years old
Sea-Foam every 2k?
Loose sparks plugs?
haven't looked at this yet to be honest :/
Thanks for any inputs
~Jij
Old May 3rd, 2012, 10:49 PM
Betcha coil has leaked it's coolant and needs replacing. What you are experiencing is classic end of life symptoms for the coil.
Old May 4th, 2012, 09:10 AM
LRover's Avatar
LRover
J. Michael McCaig
If the coil checks out it could be running rich as you said it seems fine before the engine warms up. Do you get a puff of black smoke when you rev it after it warms up? If so check for a loose hose on the fuel pressure regulator. Could also be leaky injectors.
Old May 4th, 2012, 09:46 AM
I would also guess failing coil, but perhaps also a partially blocked cat? You're not throwing any codes?
Old May 4th, 2012, 06:59 PM
jijalicious
Jiman Khosravan
'94 D90
The coil is fairly new.. but won't hurt to change it out...
But isn't the coil used the same way when just hitting the gas when in neutral as when I'm in first gear? So if it was the coil, wouoldn't I NOT be able to rev the engine?
I am throwing a code.. 68, but that's because my speedo went dead.. and just haven't had time to take a look at it.
And no puff of black smoke.
@Joshua, how would I check the cat? I'm a dog person myself (Sorry.. couldn't resist.)
~Jij
ac, start
Another hot stall thread.... 2yellowlabs Defender Technical Discussions 12 February 9th, 2011 06:14 PM
Won't Restart After Burying coast_rider Defender Technical Discussions 7 September 9th, 2004 12:44 AM
Check engine light / Rough Road mhansen Defender Technical Discussions 16 June 9th, 2004 01:14 PM
Running Hot??? Burke Defender Technical Discussions 10 March 21st, 2004 02:33 AM
Playing with Rovers, guns and a hot blonde in Africa wicks Misc. Chit-Chat 1 February 21st, 2004 09:31 AM
