Rotting floor channel door sills - Defender Source
Old February 22nd, 2016, 09:21 AM
hacksaw830
John Fields
72 Series III
I have just bought an 87 110 2.5 with a little rot, its not been delivered yet but it has the typical rust holes on the A-pillars and corners of the floor of the bulkhead near the tunnel no biggie there but the floors are rotted behind the rockers. The guy I bought it from has the channel pieces to repair it but do they weld in or rivet? anybody got any pics or advice on how they replaced there's?
Old February 22nd, 2016, 10:13 AM
If you are specifically talking about the door sills those weld in on a 5 door (form the foundation for the "b" and "c" pilars), but bolt in on two doors.
There is an under floor support that bolts on top of the chassis and supports the rear floor. These are notorious for rusting out as they are light gauge steel and are channel shaped as well
Old February 22nd, 2016, 12:12 PM
Be good if the pieces are galvy from YRM.
Old February 22nd, 2016, 12:28 PM
hacksaw830
John Fields
72 Series III
They look galvanized, Im going to POR 15 or hammerite rust cap them after they are installed anyway. guess Ill be getting out the plasma cutter to remove them and my old millermatic to put the new ones in. Wish me luck.
Old February 22nd, 2016, 01:19 PM
hacksaw830
John Fields
72 Series III
Just looking at the repair beams that come with the truck, they look like for the door bottoms. do anyone make the floor channel section or will I have to buy the entire section with the B pillar attached
Old February 22nd, 2016, 05:19 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
You could get some "c" channel and weld it in with out taking the B pillars off. It is the quick way but may not be the best?
Land Rover 110
Old February 22nd, 2016, 06:10 PM
86Defend110
Jesse
86 Defender 110 LS 5.3 In Progress
If this is the piece you are referring to, you can buy them separate from the pillars. In reality it is just a piece of C-channel with the holes drilled in it and you could make your own a lot cheaper if you wanted to.
Land Rover Defender CSW & Series LWB Sill Rail LHS - YRM Metal Solutions
channel, door
Rear end rotting out Defender 90 WOVOKA Defender Technical Discussions 6 May 13th, 2011 11:22 PM
Where to purchase door repair channel? dave_lucas Defender Technical Discussions 22 May 16th, 2009 02:16 PM
rotting doors... bharris Defender Technical Discussions 8 May 13th, 2009 03:42 PM
Want to trade Yellow Sills for Yellow Sills themaxx Wanted 4 October 25th, 2006 02:28 PM
New LR - Sweet and rotting the bank account paulb Misc. Chit-Chat 9 April 12th, 2005 07:28 PM
